Question about Krups XP5220 Espresso Machine & Coffee Maker
How do i prime an xp5220
How do I prime xp5220 espresso maker
    Sergeant:
  • 361 Answers
You should be really need to prime it all. Check where the water reservoir is installed for blockages or dirt. There should be O-rings present, these may have become dislodged.
Posted on Mar 01, 2014
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: Regarding a Krups xp5220 coffe-maker
Hi 3_141644,
If you want to replace the steam wand of your Krups xp5220 coffe-maker, please follow the steps below.
1. Remove the nozzle. In order to remove the nozzle you have to pull the slip ring down and pull straight off. It will requires a bit of force.
2. Please be careful, if you pry one of the 3 tabs which are in a vulnerable position they will break and then the steam wand may not stay on under pressure.
--> Once you understand how to properly remove and install the nozzle, it's not a problem.
Note: the steam wand is extremely fragile, please look at it's sideways and it may break.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 19, 2011
Need to open front panel to check defective switch on front panel
there is 4 skruws from the front you will seen them remove the filter holder and you will see on the age if it and you have some at the back then you lift up slowly from the front upwords
Oct 10, 2015 | Krups XP5220 Espresso Machine, Precise...
Pump may be broke
Remove the frother nozzle: if its the early type with three hooks, slide the frother body down before trying to remove it. Disassemble the frother and clean the three holes in the end. If the holes are blocked, the steam can't escape. If it's not pushing hot water through the coffee holder, pull out the water reservoir, and remove and clean the grid plate assembly where the coffee holder clips in.
Feb 08, 2014 | Krups XP5220 Espresso Machine & Coffee...
Keeps saying prime. I've unplugged and restarted, refilled resevoir.
I unplug the unit and it reset. The Prime light went off.
I unplugged mine and the unit reset and the Prime warning went off
Http://www.buyicemachines.com
Feb 28, 2012 | Keurig B60 Coffee Maker
How to prime coffee maker
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 24, 2011 | Keurig B60 Coffee Maker
The coffee isnt coming out. At the top of the coffee maker it says prime.
heatman101
Sep 21, 2011 | Keurig B50 Coffee Maker
Machine says to prime afer brewing. How do you
heatman101
Jul 26, 2011 | Keurig Platinum B70 Coffee Maker
I have krups xp 5220 and it doesn't make foam. There is just black caffe. please help me. thank you :)
Three things to try:
1. Try a finer ground coffee
2. Use fresh coffee not old coffee
3. Make sure the coffee is pressed down well in the filter holder
For the machine, make sure it has been descaled correctly.
Hope that helps.
Nov 03, 2010 | Krups XP5220 Espresso Coffee Maker
I have a Briel ED 132A Classic how do I prime the pump for the st
Sometimes the self- priming pump feature may not work due to a momentary "air lock" condition. If water does not flow from brew head, place a cup under the steam frother. Open steam control and turn the switcher onto the icon of the half-full cup until water flows from steam frother. Turn off steam control, as Espresso maker is now ready.
Manual is located here:
http://www.smithagy.net/BrielInstructionManual.pdf
Mar 15, 2009 | Briel Sintra ED-132 Espresso & Coffee...
Krups XP5220 Espresso Machine & Coffee Maker Logo
138 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
