Question about JAKKS Pacific 2011 Big Buck Safari Hunting Video Game
Does not work with av plug ins - JAKKS Pacific 2011 Big Buck Safari Hunting Video Game
WHAT DO I PLUG IN THE BACK OF THE TV/DVD COMBO?
You may not have AV ports, AV ports being the ports that you would plug in a yellow video and a white audio cable into, so you may want to take a look at some adapters. Maybe an HDMI to AV adapter?
Tmvel mini RCACVS 3 RCA Composite Video AV to HDMI Converter for TV PC PS3... This one may cost you a bit, but if you don't have AV ports, but do have an HDMI port, this should work.
Dec 09, 2015 | Video Game Consoles & Games
I have sound from my xbox but no picture ?? It's on the side av channel. Did work and tried all the leads.
should be white plug and a red plug and a yellow plug . It could be plugged into component in rather than AV in . Looks almost the same the two different inputs . Component and AV. on the TV
Jan 04, 2015 | Video Game Consoles & Games
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
I have a mikomi ctv14440, and it is meant to be able to switch av so that you can plug in a game console,camera in the back.the problem i am having on both sets that i have just bought for my kids is...
The mikomi ctv14440 I have has a scart socket on the back. Plug in an scart to av phono adaptor which has an input/output switch. Set the switch to input and press AV on the remote control. Now you can use the mikomi ctv14440 as an AV monitor with suitable leads. Press TV on the remote control to return to normal TV.
Dec 28, 2009 | Televison & Video
I can't get Xbox 360 to work. I hve old TV, using converter box
If there's an issue with the AV cords themselves, the xBox's ring will flash red in all four sections.
You might want to try clearing out any dust or debris in the plugs and plug-inputs with some compressed air.
That's all assuming the AV cords or the converter are the problem.
Dec 03, 2009 | Microsoft Video Game Consoles & Games
I have a Samsung PS42D5S TV. Everything will plug
Why don't u plug it in HDMI connections.Take off the presure to the AV -In.To much AV-out that the cause.May could be the cable is bad also.
Sep 06, 2009 | Samsung PS42D5S 42 in. EDTV-Ready Plasma...
No matter what tv i plug this console into, it does not work
my n64 part is not working the part u plug n the tv
Sep 01, 2009 | Nintendo 64 Console
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Nothing on the TV when I play Super Nintendo
it has to be the av connector as if you are turning on the console something would flash on the screen in any case
Jan 17, 2008 | Nintendo Super NES Console
Earphone, Av out and Av in problem
Plug into the offending sockets to see if that changes anything. If that doesn't help:
Contact support@Aiptek.com
This video helpful:
http://bestcamcorderreview.com/watch-video/2inPc0vlKF4/fishycomics/aiptek-mpvr-show-1.html
Jan 01, 2008 | Aiptek MPVR Digital Camera
JAKKS Pacific 2011 Big Buck Safari Hunting Video Game Logo
27 people viewed this question
Top JAKKS Pacific Televison & Video Experts
Electro Med Services...
Are you a JAKKS Pacific Televison and Video Expert? Answer questions, earn points and help others
