Question about Gaggia Coffee Makers & Espresso Machines
Gaggia accademia is leaking water from below
Does not leak when idle, only when making espresso or when turning off
5 Suggested Answers
SOURCE: Our Vienna, Superautomatica leaks water from underneath
your problem may be in the watertank. I had that problem, and found out, the metalfeder fastened so it stayed open, after making a cup of espresso.
Posted on Nov 23, 2008
EsWorld
  • 1618 Answers
SOURCE: espresso gaggia titanium. Water Tank leaking
The o-ring on the bottom of the water tank is either missing or not seated properly.
Posted on May 11, 2009
EsWorld
  • 1618 Answers
SOURCE: When I pull a shot
The gasket in the head needs to be cleaned or replaced.
Posted on Feb 22, 2011
multilinkent
  • 739 Answers
SOURCE: Gaggia Syncrony Digital Water leaking out
HI.
did u mean water is leaking under the machine,
if it is usually because chamber is filling with coffee powder and water can not make it drain tray, you can replace the O-rings on a white plastic valve piston and gaskets to the unit that drink, and clean out the small chute drain tray from space.
Download Gevalia Product Manuals here
Also look at some of the troubleshooting process is often done..
LINK 1
LINK 2
Posted on Jul 17, 2011
Gaggia cappuccino xtwo. What is error code 1?
Im not sure if this will help but I've got some Gaggia Accademia Error Codes, maybe they are the same as the Gaggia cappuccino xtwo.
Hope it helps. https://wll-documents.s3.amazonaws.com/Gaggia/Accademia/Accademia%20Error%20Codes.pdf
Apr 05, 2016 | Gaggia Coffee Makers & Espresso Machines
Gaggia accademia
Most likely a connecting pipe might have come loose or leaked, boiler leaking might also be possible
Jul 17, 2014 | Gaggia Coffee Makers & Espresso Machines
Gaggia accademia grinds too much
Make sure that your brew unit is clean and lubricated. The CPU on the machine uses the brew unit to calculate the amount of coffee it grinds. If the brew unit is dirty and hard to turn strange things will happen.
Service Center information.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Apr 27, 2014 | Coffee Makers & Espresso Machines
Can an owner of a gaggia academia get a repair manual for it. i need to get into mine and see why its leeking
You can buy one from america. http://www.shop.partsguru.com/Gaggia-Accademia-SUP038G-Service-Manual-SUP038G-Service-manual.htm Ive got a problem with mine too and thats the only one i found so far
Jul 23, 2013 | Gaggia Espresso Machine Academia Model...
My new accademia gaggia won't work, error code 05
see this causes and fix it. God bless you
Reset the code read your instr. manual
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord, the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 1003380 Accademia Espresso Machine
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
Espresso gaggia titanium. Water Tank leaking
May 10, 2009 | Gaggia Titanium Espresso Machine
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Coffee Makers & Espresso Machines Logo
149 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
