Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Need color coded wire diagram for 96-99tahoe gmc truck suv
Starter clicks. After installation. Of new switch
  • 22 Answers
SOURCE: need a wiring diagram for 1994 s10 blazer 4.3 vortex
that's simple --got a printer
well free create a free log on autozone.com
next let your fingers do the walking --point and click --better than a HAynes or Chilton ---will be vehicle and engine specific --another note woth making --if the vacuum diagram ever peals off in the engine bay/fan shroud --you can get that off the site too --I'd suggest downloading and saving or print it and keep it in the glove box ---at some point you WILL need it
there are up to 4-5 diagrams available for the blazer ---print them all if need be then compare a few color coded wires and BAM --you found the right one ---easy peasy
all free
if this helps write a review--free advice and I am RIGHT
that's where I go for that stuff and seemingly only there --I don't buy their product RARELY either --I use rockauto.com
HAWK
Posted on Apr 06, 2009
SOURCE: 2000 Chevy Astro van rear ac
astro van 2000 rear a/c switch
large orange power 13.8 volts pin G
small orange pin A
blue pin B
not used pin C
not used pin D
gray pin H
yellow pin F
black pin E
Posted on May 03, 2009
co7196
  • 3433 Answers
SOURCE: looking for color code (diagram) - 7 wire trailer harness/wiring
If you haven't purchased the plugs yet. The wire color codes should be included in the package.
  • If you are using used plugs ck the back of the plugs for color or function of wire
  • Wht - ground
  • red - stop
  • blue - accessory/aux
  • brown - tail
  • black - Marker
  • grn - left turn
  • yellow - right turn
Posted on May 06, 2009
  • 16 Answers
SOURCE: 1985 k10 ignition - truck will not start
Buy a Chiltons, or Haynes manual
Posted on Aug 24, 2009
  • 6 Answers
SOURCE: I need a wiring diagram for 1987 Chevrolet 3/4 ton
The Haynes repair manuals usuall have wiring diagrams in the back of book.Around $20.
Posted on Oct 16, 2009
Color coded wiring diagram 1995 gmc sierra electric windows
Google the
wiring diagram 1995 gmc sierra electric windows I found several systems offering what you require.
But what is the problem, 99% of the time in that year the window regulator was at fault, it was made from a stapped steel housing verses an cast unit. We check the left switch for power, disconnect the two wire connector at the motor, and see if the motor has power to one side or the other in the connector. If the switch has power to it, and the motor has power to it as you press the button, the motor is at fault.
Good luck.
Mar 16, 2015 | GMC Cars & Trucks
1987 gmc power window switch wiring diagram
I NEED TO KNOW WHAT COLOR WIRES GO WHERE TO THE POWER SWITCH FOR THE PASSENGER WINDOW I HAVE NEW SWITCH BUT NO IDEA WHERE ETHE WIRES GO TO WHAT PRONG.
AND ITS RAINING!
PS 1987 GMC SARFARI PASSENGER SIDE POWER WINDOW
Oct 06, 2012 | GMC Cars & Trucks
I have a set of hand controls for a 95-06 Harley with no diagram how Do I figure out witch wire from the switches go were
If you're simply replacing the controls with other controls, the color coding of the wires should be the same. Simply unplug the old wire from the plug and insert the same color wire from the new set. Now, if you're trying to install a later set of switches on an earlier model bike, you need a wiring diagram of BOTH the new switches and the old bike so you can figure out the color codes on the wires.
Good Luck
Steve
Mar 02, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Looking for the diagram for the trailer plug
check out this link, it should be helpful, has a color code for GMC and other vehicles. Let me know if you need more help or info. Good luck!
http://www.etrailer.com/faq-wiring.aspx
Jul 22, 2009 | 2004 GMC Yukon
Can't find starter wire in 1992 GMC Safari Van
dose you truck have a coded key? (a chip in it?) if it does, your out of luck, the wire is ground switched and will not show anything on the volt meter. Instead, find the small wire from the starter and use that to make your connection
Jun 12, 2009 | 1992 GMC Safari
350 Chevy starter wiring diagram needed this engine has a points style distributer there are 3 wires plus the large battery cable Solinoid Power Alt Output Ign Switch Start THANKS
IF YOU HAVE A POINTS TYPE DISTRIBUTER, THE WIRING WILL BE: TO ENERGIZE THE STARTER SOLENOID A LARGE, ABOUT A NUMBER 12 OR 14 GAUGE WIRE WILL GO TO THE INNER MOST SMALL TERMINAL ON THE STARTER SOLENOID. IT MAY BE PURPLE IN COLOR. THE SECOND SMALLER WIRE SHOULD GO TO THE OUTER SOLENOID TERMINAL AND GO FROM THERE TO THE + TERMINAL ON THE IGNITION COIL. THIS IS FOR BY PASSING THE RESISTOR WIRE FROM THE STARTER IGNITION SWITCH. THE LARGER BATTERY CABLE WILL GO TO THE UPPER TERMINAL ON THE STARTER SOLENOID. THERE MAY BE AN ADDITIONAL BATTERY FEED WIRE TAKE OFF FROM THE STARTER BATTERY TERMINAL POST ON THE SOLENOID FOR OTHER ACCESSORIES. THIS TYPE OF SYSTEM (POINTS TYPE) WAS TYPICALLY DONE AWAY WITH IN 1975 WHEN THE HEI DISTRIBUTOR CAME OUT.
May 05, 2009 | 1986 Chevrolet Nova
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
14 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
