Philips tv SLC7.1HE LA
I want to connect my laptop through HDMI port. It has got HDMI 1 and HDMI 2. But I am not finding the HDMI option in my TV or remote. When I press Menu on the TV unit also it says not available. Please help
ctf1800
  • 4402 Answers
SOURCE: Dog chewed my Philips DVD remote!
Remote codes
http://www.remotecentral.com/index.html
Posted on Mar 17, 2008
  • 1694 Answers
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
Posted on Mar 22, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
djkillerbee
  • 23 Answers
SOURCE: remote codes
GE ........... 0704 0312 0018 0002 0502
................. 0006 0007 0601 0835 0901
................. 0114 0103 0803 0806 0310
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Posted on Jun 26, 2008
mistersony
  • 320 Answers
SOURCE: Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
I am trying to connect my 32' viewsonic hdmi tv to my philips dvd
hola primeramente hay que ver si su dvd trae hdmi por que casi ninguno lo trae , de traerlo solamente tiene q buscar el cable hdmi conectarlo y seleccionar en su dvd la salida hdmi y en su tv la entrada hdmi en el men? del tv,..,. saludos.
Oct 01, 2016 | Philips Televison & Video
How can I connect Philip model 50PFP5532D to my PC using mediaconnect?
No place to put your RGB on the PC or on the TV? Your TV should have an RGB port for sure. The "green" may be yellow instead.
Your PC will need a video card installed that features a RGB output to make it work from there.
Some PCs use DVI out instead. You would then need a DVI/HDMI converter to plug into your TV's HDMI port and then to the PC.
Nov 18, 2014 | Philips 50PFP5332D 50 in. Plasma...
I have been using my panasonic tv as a display to watch films on from my laptop via HDMI however now i am just getting a black screen. the TV recognises that the laptop is connected and so does the la
try holding the hdmi wire connecting to the tv port at a slight angle, if it comes on then the hdmi connection is damaged,do you have sound?
give the connection a wiggle and inspect the connection, maybe worth a reset?
Dec 09, 2013 | Panasonic VIERA Televison & Video
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Can not connect hdml wire to my philips led tv with my dell laptop. what to do
If your laptop does not have a HDMI port then you need a VGA to HDMI converter. Connect this converter to your laptop and then connect it to the TV using a HDMI cable. You also need to connect the audio out port on the laptop to the audio in on the TV. You can get a combined audio input with some HDMI converters.
Check out this WEB site.
http://www.proaudiovisual.com.au/vga-to-hdmi-converter-adapter-and-upscaler-video-audio-full-hd-1080p/
Mar 05, 2013 | Computers & Internet
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
Connecting laptop to philips hdmi tv
you must have HDMI port on both TV and laptop. you need a HDMI cable to connect to the laptop. but first see that HDMI version of TV is compatible with laptop's HDMI.
Sep 26, 2011 | Toshiba Televison & Video
I cant find a port in which i can connect the tv cable into my acer laptop 5920
The Acer 5920 comes with two options to connect and display the desktop onto a TV.
The First Option is the HDMI port which you can identify by looking here http://en.wikipedia.org/wiki/HDMI
The HDMI cables cost around $14 - $20 at Target or Walmart
You must ensure that yourTV has an HDMI port or you will not be able to connect to it.
Also, the regular 5920 does not have an HDMI port, but the 5920G does, so check your model on the bottom of your laptop to be sure.
The second option is S-video, you can see that here http://en.wikipedia.org/wiki/S-Video
Cables are retaltively cheap, but be sure to check the connections to ensure the pins match the port.
Apr 21, 2010 | Acer Aspire 5920-6727 Notebook
Connecting a laptop to a tv
You have to tell the laptop to use an external display this usually involves pressing the FN + F5 on and acer but does vary from laptop to laptop
the second key usually has two screens printed on it
Dec 31, 2009 | Computers & Internet
I have a philips x72 laptop and i wanted to find out is it possible to connect my laptop to my TV to watch a DVD?
m not able to search the spec of ur laptop thou if ur laptop and monitor has svideo ports it will work
May 19, 2008 | Computers & Internet
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Electro Med Services...
