Question about Kocaso M M9100 9-Inch 8 GB Tablet
System ui has stopped m9100
As soon as this device is turned on it reads " unfortunately, system UI has stopped." "OK" button is present. When pressed it restarts the device to turn right back to the same screen and message.
  • Kocaso Master
  • 2,219 Answers
You need to re-load the firmware, see here Support Firmware
Posted on Feb 22, 2015
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
I have a crystalview xt android tablet or PC and my system UI stopped working
• You need to switch off your tablet
• Then press/hold power+volDOWN+home just keep pressing it
• Then it will switch on with a word start in it let go of the buttons you are holding
• You need to click on the VolDown twice so a recovery mode will appear.
• You need to click power so it will restart to recovery mode
• An android image will appear that has a red exclamation mark
• After which you need to hold down power and then press VolUP
• You need to use volume to scroll and press power to select "wipe data/factory reset"
• Then you need to scroll down again and press power to select "yes-erase all user data" This will now start your tablet to reboot Then it will switch off then switch on again.
Mar 04, 2015 | Tablets & eReaders
My tablet toshiba excite pure is saying Unfortunetly, sysyem UI has stopped. It goes off when i push ok and comes right back. How do i remove it?
Have you tried to wipe the cache partition
App data
Step 1 Press the "Menu" button and tap "Settings." Touch "Applications."
Step 2
Tap "Manage Applications," select the "All" tab and touch an application name.
Step 3
Touch the "Clear Data" button to wipe the app's saved data. Tap "Clear Cache" to remove any cached data for the app.
Phone Data
Step 1 Turn off your Android device. Reboot the phone or tablet into Recovery Mode. The process is specific to the device model. For the Motorola Droid, press and hold the "Power" button and the "X" key on the slideout keyboard. Release the "Power" button when the Motorola icon appears. Press the "Volume-up" and "Camera" buttons simultaneously to open the Recovery Console. To access Recovery Mode with the LG Ally, press and hold the "Power," "Home" and "Volume" buttons simultaneously.
Step 2
Press the "Volume-down" button to scroll to "Wipe Data/Factory Reset." Press the "Camera" button to select it.
Step 3
Scroll to and select "Wipe Cache Partition."
Step 4
Highlight and select "Reboot System Now."
Mar 03, 2015 | Toshiba Tablets & eReaders
My audiovox 7 inch tablet reads hdmi is turned off, and ui is not working,, also it wont function when I press ok
For some tablets, the HDMI port must be connected to a TV before you can enable HDMI.
Jan 10, 2015 | Tablets & eReaders
Wt is [unfortunaly, system ui has stopped working
Your android is running on low memory. Transfer some files to sd card or delete unnecessary files. Also clear data of applications at 'Manage Applications' on your menu.
Nov 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My ZEKI android tablet keeps saying that unfortunately system UI has stopped working what do i do?
You can try pulling the battery then reinstall it and restart the unit. If that doesn't clear the problem go to settings, and then applications and look for UI and clear the cache and data. If that fails you can try to do a factory reset.
Nov 09, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
What does it mean system UI has stopped working on android trio 4.3" stealth?
This probably caused by an feature called 'Face Unlock'; either uninstall or disable it. Usually this done by Settings --> Apps --> (All -->) Face Unlock --> disable / uninstall.
Or when you actually really like that feature, make sure you've updated your phone and that Face Unlock app to the latest version.
PS: What it actually means is the Android System UI component has crashed (and will automatically restarted afterwards). You might see the statusbar at the top disappear and reappear after a few seconds as well ... (symptom).
Jun 27, 2014 | FUHU nabi Jr. 5" Capacitive Touch Android...
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
Mar 17, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
I push the power button the kocaso screen comes on and tells you injoy colorful life and then goes to a screen that said android for five or six seconds and then shuts off well it does not shut off it...
I used this link and found it had a 50/50 chance of working...
http://forums.androidcentral.com/android-4-1-4-2-4-3-jelly-bean/347622-kocaso-m1066-tablet-system-ui-has-stopped-working.html
I know it's not for your exact model, but manufacturers often have the same method of hard reset for all of their devices. Specifically:
"The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen and you`re done."
Hope it helps u too
Chadman
Dec 27, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
Kocaso M M9100 9-Inch 8 GB Tablet Logo
174 people viewed this question
Top Kocaso Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Rick Ostrowski
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
