Question about Singer 2250 Tradition
The needle moves and jams when I am sewing - Singer 2250 Tradition
5 Suggested Answers
  • 16 Answers
SOURCE: when sewing the bobbin will jam. the top of the
Make sure your top tension is adjusted correctly and that the thread binds between the tension plates. That's a common problem when the top tension is too loose.
I can try to help you with sewing machine problems at my forum. http://www.sewingmachineryrepair.com/forums/index.php
Posted on Feb 28, 2010
  • 460 Answers
SOURCE: singer model 7442 needle hits plastic piece under
Perhaps you have bent the needle. Or perhaps you have shifted the bobbin somewhat while removing jammed fabric.
Posted on Dec 07, 2010
  • 980 Answers
SOURCE: I was sewing along with no problem and then all of
There is probably thread jammed in the raceway area, take out the bobbin case and raceway if it is a front load bobbin
Posted on Aug 08, 2011
SOURCE: My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Posted on Apr 16, 2012
Janome JF 1014 sewing machine, needle wont move, everything seems to be jammed. Manual wheel wont move.
can only guess that the timing is off. needle and bobbin case is jammed and you need to take it t a repair shop
Mar 04, 2017 | Sewing Machines
The bobbin jams up after three or four strokes of the needle
You possibly have the incorrect bobbin type, or there might be scratches on the bobbin, or it is threaded incorrectly in the bobbin case. Hope this helps.
Mar 13, 2014 | Brother XR9000 Sewing Machine
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Consew Zig Zag CN2053R-1 needle bar is jammed
sometimes when a machine jams, the machine jumps time
taking it to a sewing machine shop to be serviced would be a good idea
Apr 30, 2012 | Sewing Machines
Elna 9000 bobbin problem
try changing the needle,,make sure the needle & thread & fabric are correct for each other
make sure the bobbin is turned the right way
it's also possible that when the needle gets jammed or broken that the machine can become out of time
and would have to be retimed at a sewing machine shop
Apr 01, 2012 | Elna Sewing Machines
This is the first time I am using this machine... it worked for a little while (15 minutes)and then the needle jammed. The whole part that moves the needle up and down doesn't move, manually or by pedal. I...
Unscrew the needle and you should be able to move the balance wheel, take the needle out and then look for thread jammed in the bobbin case area.
Mar 03, 2010 | Bernina Virtuosa 150
Getting jam all the thread and needle do not mooving
make sure your needle is not dul you may need to adjust your tension as well.
Oct 21, 2008 | Brother LS-2125 Mechanical Sewing Machine
Needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
Feb 27, 2008 | Brother CS-6000
Jammed
ROLL THE MANUAL LEVER BACK AND FORTH WITH CONTROLLED FORCE till the needle comes out! the jamming is caused by threads tangled inside the bobbin area. rolled it with a controlled force back and forth. when the needle comes out flip your machine to where you could open the bottom part and remove/clean the threads tangled on the bobbin!
place some OIL.
Nov 19, 2007 | Singer 1116 Mechanical Sewing Machine
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Singer 2250 Tradition Logo
29 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
