I am replacing the woofer in a Eurolive B1800x trying to figure out which of blue or yellow wires is positive and negative
SOURCE: 8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
Posted on May 08, 2009
  • 1121 Answers
SOURCE: Internal wiring schematic for a JBL 4311 WX-A
the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
Posted on Feb 18, 2010
SOURCE: Positive/negative connections
Bleu + (pos) Black -
Posted on May 10, 2010
esound
  • 425 Answers
SOURCE: inside the speaker cabinet, is blue wire positive
Hi, It all depends on the combination of the wires inside the cabinet.
It can be Blue and white ,and another color combination.
But the blue color is always Positive , While the White is negative.
To test, you can use a battery to check. When you put the blue wire on positive, you will notice the clarity of sound that comes out, other than when you use the white as positive.
Hope that helps.
You can write back if you need more help on that.
Thanks for using fixya......
Posted on Jan 05, 2011
  • 65 Answers
SOURCE: Does the woofer inside the
I haven't looked inside this particular model but have worked on similar. If you trace the wires back to the PCB it should be marked LF (for the woofer) and HF (for the horn).
Posted on Sep 08, 2011
I have a b415 dsp speaker that I pulled apart due to a rattle in the driver. I need to confirm the correct wire color to the speakers. I believe the red and black went to the driver and the blue and yellow...
Way to find out: The minus speaker leads go to ground at the amp and therefore are electricaally connected together... just use an ohmmeter to find which two wires are tied together and connect those to the minus leads of the speakers.
Jan 12, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
I have a 1991 Chrysler new yorker fifth avenue, I'm trying to convert the radio to a Kenwood... I've been searching for a Diagram and none of them have the colors that are on my car...
New Yorker and Fifth Ave have different colors for RR speaker neg. Does either of these match up?
1991 Chrysler New Yorker Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1991 Chrysler Fifth Avenue Car Radio Wiring Schematic
Right Rear Speaker Negative Wire (-): Brown/Yellow
Oct 03, 2010 | Chrysler Fifth Avenue Cars & Trucks
Stock audio wiring diagram
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 11, 2010 | 2003 Kia Sorento
Car radio stolen, harness cut, have replacement radio, need pin Identification for installation.
email me at iambanshee74@yahoo.com. I have diagrams I just can't send them through here. Which radio did you have?
Feb 27, 2010 | 2002 Dodge Intrepid
Trying to figure out the wiring for the radio for a 1995 nissan pick up
Here try this.
1995 Nissan Truck Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Negative Wire (-): Pink
Feb 03, 2010 | 1995 Nissan Pathfinder
Positve and negative speaker wires for 2008 chrysler aspen
Hello latinoheatj5,
According to modified life.com the speaker wire colors for the 2008 Aspen are:
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
You can go to their web site here for other radio wiring color codes.
http://www.modifiedlife.com/2008-chrysler-aspen-car-stereo-wiring-diagram/
Mar 31, 2009 | Alpine Car Audio & Video
What is the radio wiring diagram for 1992 eagle talon
1992 Eagle Talon Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger Wire: White/Black
Car Audio Front Speakers Size: 4′
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Mar 29, 2009 | 1992 Eagle Talon
Wiring diagram for audio system replacement? First time replacing a car audio system. I'm OK with wires connections but color codes does'nt match at all.... No diagram found in manual nether on actual...
2003 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
Car Stereo Antenna Trigger: N/A
pls rate
Mar 15, 2009 | 2003 Mitsubishi Galant
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
60 people viewed this question
 Grubhead
Grubhead
