Question about GE XL1800 1100 Watts Microwave Oven
My ge microwave model jvm1700 stopped heating
All other options work
  • 3 Answers
SOURCE: GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Posted on Sep 07, 2007
  • 4 Answers
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Posted on Dec 11, 2007
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Posted on Apr 15, 2008
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Profile microwave just stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
Posted on Sep 30, 2010
My ge microwave spacemaker profile model # JVM1860BF001 stopped while in use. Interior light, clock and timer work. Door vent opens. turntable doesn't work. Won't heat.
check the breaker, or check if the wall socket works. If there is power, then you need to take it for service. There are no user service options for microwaves as they are so dangerous for both super high voltage and also microwave emission. Some models do have a pull fuse on the rear, so check for that first.
Oct 04, 2016 | GE Microwave Ovens
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
I have a GE Profile series microwave model #
the magnatron has blown they are very expensive to repair i suggest you buy a new microwave
]hope this helps
Jun 25, 2010 | General Electric Microwave Oven
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
Microwave Model JVM 1870 stopped heating, all else works (timer)
heatman101
ggk
Nov 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
