Question about Toro Snow Blower Ccr 1000 Belt 715381 715381 71 5381 ()
Toro ccr 1000 engine wont start - Toro Snow Blower Ccr 1000 Belt 715381 715381 71 5381 ()
sparksflyin
  • 47 Answers
SOURCE: toro powerlite ccr model#38175
seems to me you have water or dirt in you carb pull the carb off take the bowl off clean it real good try to do so over a bowl or bucket to see the fuel that comes out to determine if its water or just dirt
Posted on Feb 05, 2009
SOURCE: i have a toro ccr 3650 snowblower the electric start just grinds
This problem has been solved! I took the covers off the machine, removed the starter and eventually replaced the drive. Apparently the drive parts were put on back ordered and took about 4 weeks to get the drive set. One thing I suggest if anyone does this is to look at the fly wheel to insure it's in good working order. The dealer I worked with said often that is chewed up (the teeth on the fly wheel) and leads to a bigger headache. Fortunately mine was just fine. The machine now works likes like new as I put in a new spark plug as well!
Posted on Mar 24, 2009
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Posted on Jan 08, 2010
Testimonial: "Thank you for the quick response."
  • 122 Answers
SOURCE: Toro CCR 2450, Common starting problems? Fresh
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
Posted on Feb 02, 2011
barterjoe
  • 344 Answers
SOURCE: I can start my toro
The main jet of your carburetor is clogged. You can view this part at a site like www.arcolawn.com and order the replacment gasket set right there. clean out the jetting and you will be up and going.
I hope this helps.
If so please vote my fix up
Joe
Posted on Feb 12, 2011
I have a toro snow blower that wont throw snow
then you need to see if the belt is still in one piece... then inspect what else would cause this issue
Oct 10, 2013 | Toro Snow Blower Ccr 1000 Belt 715381...
Starts and stops starts and stops blowing snow, is the belt lose or waren or streched ? model 3650 6.5
Take the black cover off of the side (left) and look at the belt. It is probably worn out.
Mar 03, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
Feb 25, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Toroccr2000 ran fine yesterday, today it starts but wont get up to speed and after 20 sec. or so, dies. I have not yet tried to fix anything yet. Hoping for guidance.
It is difficult to know without hearing the engine run but the most common cause of poor running is the fuel system having varnished fuel in it. If you get your model number and look it up at a site like www.arcolawn.com you can order the carburetor rebuild kit. Instalation is simple and can get you up and going at minimal cost.
I hope this helps. Please vote me up if my fix was useful.
Joe
Feb 03, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
I have a CCR 3650 Snow Blower ,The engine is racing at idle. How do I adjust?
Try the spring on the governor. sounds like it's not hooked up, or extremely week. I rebuild and sell these all winter. I've had it happen a few times. Runs really good! but, will ruin the motor running over speed like that. There are adjustments- some have the spring on a long flange of metal so it can be bent backwards to add tension- it doesn't take much! If the motor starts to rev up and down and up and down, add a hair more tension. It there is too much tension it will stall out when you hit heavy snow.
Feb 01, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Cannot start Toro 1800 snowblower (electric) inserted key, power connected...
Can you pull start it? If so,you may need a new starter gear,about $30,they're plastic & wear out.
Jan 12, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
What is the gas to oil ratio for a ccr 1000 snow blower?
the ratio is 50:1.that is 2.56 oz. of oil mixed with 1 gal. of gas.
Dec 26, 2010 | Toro Snow Blower Ccr 1000 Belt 715381...
Toro Snow Blower Ccr 1000 Belt 715381 715381 71 5381 () Logo
103 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
