Question about Toshiba 32HL67 32 in. LCD Television
Screen problems on startup
Screen problems on power up
How do you fix a corrupted bios?
I don't think it's corrupt bios, maybe a virus or malware.
But if you can go to the computers maker website and download bios and install them the way they tell you to install them.
Feb 01, 2016 | Computers & Internet
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Power Problems!!!
i think you have LCD problem but first you check the pC startup full or not.
if pc complete startup then you connect with monitor .
i hope you something see on screen
if not problem solve then mail me
and tell me what happen
aftabsura@yahoo.com
Apr 09, 2009 | HP Compaq Presario v3000z Notebook
Emachine W2047 No BIOS Start Screen
Replace motherboard. Processor socket burnt out, contact me for further support at compdoctor2005@btinternet.com
Dec 07, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Black screen
. Same problem as above, re lation gets a black screen after initial startup prog and nothing else, no writing on screen at all
Sep 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Plasma no picture, fades to black from startup logo
UPDATE:
I finally isolated the problem, the problem has to do with the Y SUSTAINER BOARD not receiving enough/necessary voltage when turned on, while initially thinking it was just the yboard was the problem, i replaced the Y sus board with no success, with only further diagnosis, i discovered the board voltages coming from the powersupply, there are 5 voltages that relate to the Y sustainer board, VA, VSC, VS, VE, VSET. they all supply a certain voltages that all have to be supply the correct voltage in order for the y sustainer board to be working, well guess what, the VA line, which for my set needs 70volts, which upon startup quickly drops from 75volts to a jumpy 8.5-9.5 volts, which of course is nowhere near the 70 volts needed, so this quick drop in voltage is directly related to the screen fade upon startup, i found the problem now the real problem is finding a replacement power supply. hope this helsp anyone with similar issues.
Mar 02, 2008 | Dell W4201C 42 in. Plasma HDTV
No startup screen
Hi there
This not a firmware problem , but a Mainbaord issue.
If the unit is still under warranty they should replace it free of charge.
If not - then brace yourself for a costly exercise
Feb 23, 2008 | InFocus IN72 Multimedia Projector
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Toshiba 32HL67 32 in. LCD Television Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
