Question about Smeg Dishwashers
No power after blocked drain dishwasher
Smeg Dishwashers dwa149s has water remaining after wash. After cleaning out water, no lights come on; checked filters, spray arms, water inlet and drain. What should I try next?
  • Smeg Master
  • 17,328 Answers
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Posted on Feb 08, 2014
4 Suggested Answers
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: check water light is on
I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
Alan
Posted on Jan 17, 2009
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
Smeg dishwasher problems
Check the screen, which is under the bottom wash bar. You need to pull out and clean and then see if it will drain. Also listen to make sure the drain motor is running, it also could go bad on you.
Aug 25, 2014 | Smeg Dishwashers
I cleaned out the filter on my Smeg integrated dishwasher, model D16012, yesterday then started a fully loaded cycle. The items were all clean when I unloaded but some water remained in the bottom of the...
It may be possible that something fell out of the filter and into the drain pump. The machine will do a short drain cycle at the start of a program and if it is jammed or blocked, this will cause this problem.
Jul 02, 2014 | Smeg Dishwashers
HOW DO I DRAIN WATER FROM MY SMEG DISHWASHER
There is a screen filter at the bottom of most dish washers, if the screen gets dirty it probly won't drain properly. Check the screen and clean if neccesary. If not that, then pump may be getting weak.
Jun 25, 2012 | Smeg Dishwashers
Water hasn't drained and combination of lights notin troubleshoot
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Mar 29, 2010 | Smeg STX2 Dishwashers
Smeg dishwasher Beeps when trying to drain...seems to wash ok but
Check your air gap at the sink for internal obstructions (take it aoart and clean it) Also check the dishwasher drain outlet into the garbage disposal (if you have one) They tend to clog up inside the garbage disposal. You may have to pull the hose off that connects to the garbage disposal to clean the hole out.
Kelly
Feb 28, 2010 | Smeg 24 in. DWI612 Built-in Dishwasher
No water filling dishwasher after paper napkin got caught up in wash and blocked drain holes.
First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris. If this fails and no water is entering the machine then the most likely cause of the problem will be a defective water inlet valve or logic controller board and both will need checking and / or replacing by a service engineer. In this case it is most likely that the water inlet valve has become defective and will need replacing. This is quite a common fault with dishwashers and washing machines and is a relatively simple and cheap repair.
Sep 24, 2009 | Smeg Dishwashers
Spray arms don't spin on Smeg DWF 410 ss
Remove he wash arms and visually check for obstructions in the holes where water sprays out if any number of these are blocked it will happer the turning of the arms
Jan 21, 2009 | Smeg 18 in. DWF410SS Slim-Line...
My dishwasher want run any cicles
check the out flow tube and see if its blocked..... if its not see if the food grinder in the bottom is blocked
May 28, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Smeg dishwasher EN50242
have a Smeg STX-45 dishwasher. After washing the utensils, machine is not able to drain the water. Can you please tell me what could be the problem. Is there any switch I need to press for the same or something else. I have used the machine for the first time.
Oct 12, 2007 | Dishwashers
Dishwashers Logo
306 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
