Question about Cycling
Schwinn serial I have an old Schwinn with a serial number on the bottom of the shaft that the pedals go into. I've been trying to look up the serial number with no luck. Hoping you can help. The number is G902539. Any info would be appreciated.
  • Tanda T
    Tanda T Feb 08, 2014
    Also it is a red le tour with white handlebars.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
July 1979.
Posted on Aug 03, 2014
4 Suggested Answers
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
bikeservice
  • 34 Answers
SOURCE: I HAVE A SCHWINN 3 WHEEL ADULT BIKE. IT IS VERY
Trikes are normally not made to ride much more then just around the block do going up even the smallest grade will be difficult. You could change the gearing but I suggest looking into adding a 3 speed hub if you are planning to ride more then a couple miles or live in a hilly area. You should contact your local bike shop.
Hope this helps!
Posted on Jul 22, 2009
ftw1952
  • 10319 Answers
SOURCE: Trying to determine year of a specific Schwinn Panther bicycle.
1949 is the year of this serial number
Look at this website to verify my findings
http://www.re-cycle.com/history/Schwinn/SwnB_Serial.aspx
Posted on Mar 13, 2010
Testimonial: "Thank you very much for taking the time to research and find the information in regard to my wife's bicycle. You have been extremely helpful. Ron"
What year is my schwinn FB08291
Congrats! Your bike is an original Chicago Schwinn.
Built: JUNE of 1966 Search Results
Schwinn serial number lookup tool
schwinncruisers.com/serial-number.html This tool searches a database of Schwinn serial numbers and if it finds a ... box and click "find" to see what date and year your Schwinn bike was manufactured.
Schwinn Serial Numbers and Date Codes - Re-Cycle
re-cycle.com/History/Schwinn/SwnB_Serial.aspx All serial number records before 8/18/1948 were lost in a factory fire. ... If you have a Schwinn from this era, please, PLEASE send us pictures of your bike and serial number (Cutter@Re-Cycle.com). We are in the process of collecting pre-1948 serial numbers in the hopes of rebuilding ...
THE SCHWINN DATE CODES BY YEAR,MONTH AND DAY - Angelfire
www.angelfire.com/rant/allday101/SchwinnCodes1.html/ THIS CHART APPLIES TO CHICAGO SCHWINN`S ONLY. SCROLL DOWN FOR THE DATE CODES LINKS BY FRAME LOCATION OF THE SERIAL NUMBER.
How to Identify a Schwinn Bicycle ' Gone Outdoors ' Your Adventure ...
goneoutdoors.com/identify-schwinn-bicycle-6115826.html Schwinn bicycles are easy to identify by the Schwinn logo displayed on the bike. ... Johnson Outboard Identification · What Is the Difference Between a Schwinn ...
Schwinn serial number result
Jun 18, 2017 | Schwinn Cycling
Bike serial number, Schwinn voyageur 11.8 , front below handle bar says japan 1080, below seat says 4130
1080 is date code for Oct 1980. Value? Too many variables. See my tip for more info:
How to determine the year value etc of your bicycle
You can also Google "Schwinn voyageur 11.8 craigslist" to see what some people are asking. Mechanical and cosmetic condition, original parts and accessories are big variables.
Jun 01, 2017 | Schwinn Cycling
Schwinn cruiser frame serial number U22Y48168 under crank, forward facing drop out. the tubes run on outside of seat post, not welded into it on both sides. what can you tell me about this frame?
The serial number alone is not always helpful, including in this case. You need to specify what the model is (written on frame or chainguard). If the bike has been repainted it does not matter much how old it is, most of the value is gone. Look for an additional number on the head tube - may have a date code. Google "Schwinn serial number" for more info or check my tip:
Jun 08, 2016 | Schwinn Cycling
Date of manufacture of predator serial number 00583 schwinn
That is better, now we have something to go on :>)
http://re-cycle.com/History/Schwinn/SwnB_Serial.aspx
Lots of info
  • Schwinn Serial Numbers and Date Codes - Re-Cycle re-cycle.com/History/Schwinn/SwnB_Serial.aspx Schwinn Serial number and date code ... Schwinn Serial Numbers and Date ... out the crankset to check for a date code. If you have a Schwinn from ...
  • Schwinn Serial Number Info - BMXmuseum.com Forums bmxmuseum.com/forums/viewtopic.php?id=18201
    • LAST UPDATED: 2013-05-10
    • 51 POSTS
    • FIRST POST: 2007-06-28
    Schwinn serial number sequences, ... separate date code number on the right rear fork end that ... I have a 1980 schwinn predator.
  • Schwinn serial number date codes - Angelfire www.angelfire.com/rant/allday101/SchwinnCodes1.html this chart applies to chicago schwinn`s only. scroll down for the date codes links ... if the serial numbers are found on the left rear dropout
  • Determine the Manufacturing Date waterfordbikes.com/w/culture/paramount/paramount-dating Determine the Manufacturing Date. ... Schwinn would add another digit, ... serial number 018524. All Paramount tandem production had ceased by the end of 1979.
  • Schwinn Lightweight Data Book (Serial Numbers) schwinnbikeforum.com/SLDB/serial.htm Serial Numbers Chicago built Schwinn Serial Numbers for the ... a letter representing the month of manufacture, a number indicating the last ... Schwinn Date Codes ...
  • Schwinn serial number lookup tool schwinncruisers.com/serial-number.html Vintage Schwinn serial number lookup. Enter your Schwinn serial number in the box and click "find" to see what date and year your Schwinn ... Schwinn serial numbers ...
  • Bike serial numbers https://bikeindex.org/serials Serial numbers All bikes 1 all have unique serial numbers. Most bicycles have their serial number engraved beneath their bottom bracket, but sometimes serial numbers ...
  • How to Date Schwinn Bicycles ' eHow www.ehow.com > Hobbies, Games & Toys > Hobbies > Antiquing How to Date Schwinn Bicycles. The Schwinn Bicycle Co. is an American bicycle company and a ... For Schwinn's the serial number location has moved to ...
  • Nov 10, 2015 | Schwinn Cycling
    I have a old schwinn bicycle and the serial number is H10090. what year is it ? how old is it ?
    put "Schwinn date codes" in your searchline. the location of the serial number is also important. follow the instructions on the site
    Mar 03, 2015 | Schwinn Cycling
    I have schwinn stingray bike but the frame serial number doesn't appear to be a schwinn number. would JAK 13245 be a schwinn serial number
    It doesn't appear to be a Schwinn frame. I suggest that someone has switched out a phoney frame, added Schwinn parts and sold it as a genuine Schwinn. Schwinn date codes are available on-line.
    Oct 12, 2014 | Cycling
    Schwinn bike serial numbers
    The Schwinn Super Le Tours were made in Japan from 1976 to 1985. Your serial number "K6" would have been made in November 1976.
    Jul 18, 2014 | Schwinn Cycling
    What does it mean if I do not have a serial no. on my Schwinn 'world' frame?
    Its usually under the bike below the pedals. all schwinn bike have serial numbers. Sometimes then put them other places but should should hav numbers, unless its a china nokoff. cheap replica.
    Hope this helps, God Bless :O)
    Apr 23, 2014 | Schwinn Cycling
    Bicycle serial number
    Here is a place that looks up serial numbers for Schwinn. According to the site, your bike is from 1965.
    Mar 27, 2014 | Schwinn Cycling
    Mar 13, 2010 | Cycling
    Cycling Logo
    119 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
