Question about HP f1905 19" Flat Panel LCD Monitor
No sound from monitor
There is no sound coming from my monitor when i play games
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Sound aoc l22w861 lcd tv pc monitor
It may be the game options or the system options may be set to something else than speakers
Mar 20, 2014 | Sony Playstation 3 (PS3) Console
Golden tee black screen
Are you able to advise some more detail for this issue please?
Can you play the game 'blind', which means coin it up, start a game and hear the game making normal gameplay sounds? If so this shows there is an issue with the monitor, or the wiring to the monitor.
Are there any lights lit up on the main game board inside the cabinet? If so this also shows there is an issue with the monitor, or the wiring to the monitor.
Is there any neck glow on the monitor tube, which is the back of the tube itself where it narrows down like a funnel to a narrow glass tube? If so this would indicate the monitor is most likely functioning and could be a game board issue.
You can also determine whether a monitor is functioning by turning up the brightness to full using the brightness potentiometer on the monitor chassis, or the potentiometer on the flyback transformer. The flyback transformer is the plastic looking device that the high tension lead comes out of and connects to the monitor tube, a lot like a spark plug lead connects from the cars distributor cap or coil pack to the spark plugs. It should show a lighter screen and probably with lines in it if the monitor is running.
Jan 24, 2014 | Arcade Golden Tee Unplugged Video Cabinet
When i play a game the monitor goes into power save mode and will not come out .i have a Alienware Aurora with a dell st 2410 monitor
This is usually due to a resolution problem. see if you can reset the settings to default in the game. sounds like you are trying to play game in a resolution the monitor doesn't support.
Nov 04, 2010 | Computers & Internet
While playing a computer game, the monitor will go black, and then come back. i am playing world of warcraft.
Um, its because your useing the monitor too much. if you keep it up your monitor will break due the the high graphics of warcraft. and it will **** to have to buy a new one :D so i suggest you stop playing so much
Jun 14, 2010 | LG 22" FLATRON LCD Monitor
Acer X193w-- input not supported..
This is likely a screen resolution issue.
That monitor has a native resolution of 1440x900 (I used to have one). If the game is feeding the monitor too high a resolution, the monitor can't display it and.....input not supported. So, if the game has a configuration option (without going into the game itself) set the resolution to 800x600 and try to play. If it works, bump up the resolution until it looks acceptable.
Hope this helps!
Aug 21, 2009 | Acer AL1916W 19" LCD Monitor
Monitor screen goes blue after game install.
You have an incompatability between the drivers and Windows. Uninstall the games. Is everything all right now? Upgade your video and sound drivers. You can download these from the manufacturers web site. Now reinstall the games.
Mar 21, 2009 | HP w2207 Monitor
W3107 no signal from computer to monitor
check the requirements of your game who you played maybe your VGA card cannot support the requirements of the game. and also check the resolution maybe it cannot support.
Jan 07, 2009 | E-Machines eMachines Desktop PC
No signal
This sounds like your Video card might not be compatible with the game you are playing. You might need a better video card. Before you do anthing else, check to see if your computer is fast enough to play it.
Big games can crash slow computers, also it could just be a bad monitor.
Try checking the cord between the monitor and the computer.
Feb 23, 2008 | Acer AL1714 17" LCD Monitor
Wavy lines, goes black during video games.
It sounds to me like the monitor's refresh rate is too low to support your current settings, and the demands of the game. Have you tried adjusting the refresh rate? If I'm right, you should be able to fix the wavy lines that way. I'm not sure how much control over the refresh rate the game takes, but if you can fix the wavy lines and the game still doesn't work, I think you're not likely to get the game to work on this monitor.
Aug 28, 2007 | Proview PL926WBi 19" LCD Monitor
HP f1905 19" Flat Panel LCD Monitor Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
