Question about Frigidaire 4.6 Cu. Ft. Beverage Cooler
My unit will not go below 41 degrees... - Frigidaire 4.6 Cu. Ft. Beverage Cooler
    New Friend:
  • 46 Answers
I would remove the compressor cover panel and check the condenser coils for being clogged with dirt and dust. Clean if needed. While in there check to see if the compressor is running hot. Operating very warm is normal but too hot to touch is Bad. If that is not the problem, I suggest recovering the refrigerant gas in a tank and replace the receiver drier by welding in a new drier and recharging the system with new clean R134A gas
Posted on Feb 08, 2014
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
I bought a used True commercial refrigerator model GDM-41 the temp. remains at 60* no matter if i move the thermostat up or down it remains at 60* I noticed that the thermostat was replaced and has a...
Hello Margarito539,
I understand that you purchased a True GDM-41 merchandise refrigerator and you are having a problem with the temperature. The thermostat you are currently using is an in-line thermostat and is not the proper thermostat for the unit I would suggest that you follow the below link and purchase the proper thermostat for the unit. http://restaurant-equipment-parts.com/part/true/800393 the cost is $36.98 and is an OEM part.
You also may need a service tech to check out the freon in the unit. The unit uses 134A freon and must be within a few ounces of charge other wise it will not work properly. As the unit is keeping it 60 degrees, before you do anything make sure that you can hear the compressor running as this is not a cheap fix, however may be worth the cost for the unit you have. The compressor should be humming if it is not and the unit has been plugged in for a while, unplug for about thirty minutes and let the compressor cool. Once thirty minutes has passed plug in and see if the compressor is humming.
After checking the compressor you have two choices if it is humming call a service tech and have them check the freon charge and thermostat or change the thermostat and see if the compressor starts cooling the unit. If the compressor is working then the box is well worth fixing, if the compressor is not working you need to decide if it is worth fixing. A used unit with a one year parts and labor warranty costs $2100 so the repair should not cost over $1000 to be economical.
Thank you for choosing FixYa.com
Justin
Apr 20, 2011 | True GDM-41 Refrigerator
I get the wrong answers when i'm trying to calculate sinus tasks. ex: sin 41 = -.9165215479 and the right answer is: 0.66 why?
I have no idea where you got that particular value of a sin (41).
At first I thought you might have been using the radian as angle unit, but that is not the right answer. I tried cos (41 radian) and I got -0.9877392775.
Any way, when you are using angles you must select that appropriate angle unit ( appropriate to your problem, that is).
I suspect you need the angle unit to be set to degrees. If you do you will find that sin (41 degrees)=0.656059029 which is close to the rounded up value you call the "right answer".
To set the angle unit to degrees
  1. Turn calculator ON
  2. If you see no icones, press the [MENU] key.
  3. Use arrows to highlight the RUN icon or press 1.
  4. In RUN screen, press [SHIFT][MODE] to enter the (SetUp)
  5. Press the down arrow 4 times to move highlight to the line Angle.
  6. From the three tabs that appear at the bottom of the screen, select the one labeled Deg ( by pressing the F1 key) and press [ENTER.]
  7. Calculate the sine with the angle unit set to degree and you will get the value you are expecting.
Nov 23, 2010 | Casio FX-9750GPlus Calculator
My refer is at 41 degrees just had the difusser
Maybe your evaporator needs cleaning, I'd check that.
Feb 03, 2010 | KitchenAid KSRS25IL Side by Side...
Not cooling proberly. Unpluged unit for 5
return air ducts are frozen and need to be defrosted. unplug unit and with doors open , introduce warm air from a blowdryer for a couple of hours , the ducts that are frozen are behind the rear panel on the rear wall of the freezer
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezing temperatures effect on LCD television
It shouldn't have any bad effects on the display. When LCD panels get cold they may exhibit slow response time, like trails or a persistent display when action is moving. As long as you don't experience SUDDEN temperature changes you should be OK
Oct 17, 2008 | Televison & Video
Kitchenaid KSRA22ILSS02 fridge won't get below 41 degrees
Try shut down for overnight and turn back on next day. I had same problem - cooling air duct was blocked by ice
Oct 08, 2008 | KitchenAid KSRA22ILSS Side by Side...
Beer Not Cold!!!
There is a temperature control knob on the back side of the ref. it is on the bottom by the compressor
Have you adjusted this?
clayfoot
Aug 09, 2008 | Frigidaire PLKU1267DS Stainless Steel...
Humidifier not taking out water
I have the same problem. I have had the unit less than a month. Haier's policy is for me to pay $14.99 so they can send me another one. What a huge ripoff.
Jun 03, 2008 | Haier 65-Pint Dehumidifier
Frigidaire 4.6 Cu. Ft. Beverage Cooler Logo
107 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
