Question about Boating
My 50 ho 4 storke was stored for over a year it started like a dream and idles great but when you advance the throttle to mid range it seems to de tune and misses like crazy until you bring her back d
My suziki 50 hp 4 stroke was stored for a year it started great and idles great but when you bring he up to RPM at about half throttle she seems to de tune and misses like crazy until you bring it back below half throttle change water pump impeller lots of water and engine cool oil ok HELP
  • Warren Nygaard
    Warren Nygaard Feb 08, 2014
    I am leaning toward fuel as no alarm bells just runs terrible when you accelerate
    Sergeant:
  • 415 Answers
It sounds like the high speed passages in the carb are gummed up. If you have not done so already, you should probably rebuild the carb.
Posted on Apr 03, 2014
4 Suggested Answers
  • 54 Answers
SOURCE: 15 hp outboard 2 stroke running with water muffs
Impeller is at the bottom in the housing. it may take a few mins for the water to come out of the tell tale hole. Ensure that your muffs are on properly and wait for a bit. Also insure that the hole is not plugged.
Posted on Sep 14, 2009
SOURCE: 1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
Posted on Jul 20, 2010
  • 3 Answers
SOURCE: Mariner 2 hp outboard engine (1985) not pumping water
My Mariner 8 has a thermostat fitted. It only pumps water when it heats to normal temp.
If your engine stops, it may be a fuel problem. Check the plug and go to Marine Doctor (a) fuel diagnostics, (b) spark plug diagnostics, sections. PK
Posted on Aug 14, 2010
Testimonial: "Thanks Peter, we will certainly try what you have said."
What is wrong wIth my Honda xr 125 idle?
have carb cleaned ethenol kills carbs
Mar 22, 2015 | 2005 Honda XR 125 L
Jincheng scooter issue
sounds to me that your belt is slipping
try changing your belt
different manufacturers all have different prices
but most Chinese scooters all have the same gy engine and drive gear
so shop around and find the cheapest
Apr 04, 2014 | Motorcycles
Zero Turn Lawn Mower shakes on full throttle
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 14, 2017 | John Deere EZtrak Z225 Zero-Turn Riding...
1990 isuzu pickup 4cl often will NOT idle at very low rpms/under 15 mph unless I ride the brakes/E-brake and gas at same time. I know for sure I have a cracked ( in two places) exhaust manifold. The...
this car EFI, or CARB, ill toss COIN, EFI gas.
what 4 cylinder, name it there are 7 used.
I'll now toss my coin land on GAS 4 cylinder engine. (in usa?)
is it racing too fast hot
or RPM too low hot.?
we cant guess what your statement above means.
but
the exhaust manifold cracks will cause the 02 oxy sensors to LIE,
to go lean (0volts ) this cause the fuel injection
to go RICH, (cause and effect closed loop rules)
and can idle too slow. (see that word SLOW)
the wrong word you used, after reading this vast times.
"NOT idle at very low rpms"
i decode this to mean?
NOt idle at proper low RPM (800 hot)
or spec 800 rpm , is more clear
that means the idle races hot.
this word is in all books on cars. engine RACES
IF true RACES it's not :
the exhaust crack, but can be if engine EFI slams in to limphome mode, do the flash codes show 12?
you never did those did you , bad idea skipping that. Google isuzu diagnostic jumper and read.
it's not he fuel tank ever,. not RACING.
what can cause any map based engine to race
well frankly LOTS:
but can be reduced to: (physics +)
1: throttle cables jammed. no slack. bad.
2: throttle valve jammed (gunk below it does that)(in the throttle body)
3: all vacuum leaks, (put huge list here, ask)
4: ISC or ICA valves stuck open
5: engine not reaching and holding 180f will cause #4 above to fail, naturally. bad thermostat. cause.
6: someone hacked your TB. (ask)
TB = throttle body.
vacuum leaks is an all day wall of text post
i refuse. but do have links to them.
Mar 12, 2017 | 1991 Isuzu Pickup
My 4 storke quad pops and spudders when i give it throttle in mid range.is that a carb problem?
yeah, it is. clean it out and see what happens, mid range jets may be clogged
Feb 14, 2010 | Razor Dirt Quad Bike
Engine will start but wont idle
has it always been on premium? you may have to advance the timing a little to get it running right on premium if it was set for regular before.
Nov 07, 2009 | 1983 Ford Escort Gt
Husqvarna chain saw works great until its shut off then it wont start again
A couple of suggestions:
How old is the gas in the tank? If it has sat for a year in the tank or the can, the gas won't burn as easily because of octane breakdown. Mix in newly bought gas (with oil of course).
Pull the spark plug(s) and check the spark gap referring to your manual. If the gap is too wide, you'll have a hard time starting it.
It's also a good idea to check how dirty your spark plugs are, and clean if necessary.
Depending on the age of the saw, if it's 35 years old or more, you may have to put less 2-cycle oil into your mix. The ratio has changed for all 2 cycle engines if they're approximately 35 years or older. Instead of 30 to 1 it's now 50 to 1.
Sep 21, 2009 | Garden
Took apart carb cleaned and now there is no mid or high range
did u install new gaskets, the engine might be sucking air from outside the carbs. u can use a propane torch (not light) spray a little around outside of the carbs, see if engine sounds different, if it does... leaky gasket.. u might check there is no unplugged vaccum hose.
Jul 27, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
944 turbo throttle dropout problem
I would start with the TPS, and if it doesn't solve it then the AFM would be the problem.
Nov 22, 2008 | 1986 Porsche 944
Boating Logo
90 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
