Question about YouTube Videos
Dishwasher leaking Whirlpool Gold dishwasher. How do I clean the plastic filter on the inside of the door?
  • 4 Answers
Get a new dish washer or call a person you know that could had this same problem :)
Posted on Feb 08, 2014
It is not cleaning. How can I clean filter?
First of all i had !!! the same unit , we had so many problems with it I gave up and purshcast a GE cheep one. never had a problem since, but getting back to your problem , the only filter is the bottom of the unit looking inside , I dont care what they say you need to prerince everything , and use a good soap , I find useing less soap is better then filling the door cup to the top, We replaced the door switch twice and the main panel inside once and also had problems with the touch panel it is a very poor system for what you paid for this unit , good luck with it Guy
Jul 26, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher won't drain at the end of the cycle
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Stainless Steel Whirlpool Gold 24 in...
I have a GU1200XTKQ0 Whirlpool Gold Dishwasher. I
If you have a Wet/Dry Vacuum, then you can use that to **** up any debris you see in the bottom of the Dishwasher. Make sure you remove the paper filter from the vacuum so it does not get damaged from the water in the bottom of the Dishwasher. I use the vacuum trick to clean up the muck from the pump area and it works well.
Apr 04, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kitchenaid dish washer kuds24sewh4 door leaks but does not seam to be gasket ! water drips from inside of door bottom? possibly rinse aid leaking in door?
remove the inner door panel and ck for leakage . there should be water tracks . / there is a bottom seal. that may be failing / ch to see if its in proper possion .. its on the tank under the door / open the door all the way and look from inside to see. ( with a light .. mm
Dec 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My whirlpool gold isnt getting the top dishes clean, i understand it could be the filter how do i check it?
most of the times it is the food debris clogged inside the pump.to access inside,remove the spray and then 4 torx screws holding the filter csreen.pull out the screen.the u will see 1 or 2 torx screw holding the semicircle plastic cover.remove those screws and the cover.then u can cln the pump inside.do remember all the steps when openeing,that will help u when putting every thig back.
Aug 18, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Gold GU1500,water leaks under the door on to the floor
Examine the door gasket. If it is crushed or caked with detergent use some vinagar and a sponge to clean it up.
Apr 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher (whirlpool quiet partner II) leaks from the door panel
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Sep 08, 2008 | Whirlpool Dishwashers
YouTube Videos Logo
49 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
