Question about Zebra MC9090-G Wireless Handheld Barcode Scanner
How do you replace a 3D scanner to the flat bar scanner
Samsung curve 65 inch has no sound, has picture.. Using Bluetooth curved sound bar, no sound on tv speakers either
Hi!
Check your power amp circuit. Or, check if it is feed by the power supply circuit. Good luck,
Serge.
Oct 09, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
How do i fix my smart tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
May 07, 2016 | Vizio 70-inch LED Smart TV M701D-A3R 3D...
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
Hitachi tv keeps turning itself off & on every 5 mins
First thing to check would be the remote, make sure the batteries have fresh charge. I would try that first before I look to a problem with the TV itself.
Feb 08, 2015 | Shopnbc Hitachi 1080p 3D Smart LED TV w/...
I HAVE A CANON LIDE 700F SCANNER AND EVERTIME I SCAN AN ITEM THAT HAS 3D PROPERTIES THE ITEM IS BLURRY. ANY SOLUTION
A scanner is made to scan flat pieces of paper. Any 3D object will be blurry because it's not a photo camera.
Jan 18, 2011 | Canon CanoScan LiDE 700F
Scanner making clicking noise
I just got that scanner back, L1 error code on a Sharp copier. Means the scanner can't move quick enough to satisfy the specs.. Removed the lock, not needed. Oiled the bar, scanner works ok now. Will look for Triflon lubricant, my favorite. Will check with local repair shop for recommended lubes. That light sensor switch is not necessarily on your unit, but I see them on a lot of machines. Sometimes it's just a little tab or button, hard to find. Check the freedom of your scanner bar. Temporarily loosen the drive if you can. The bar must move freely.
Jul 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Silver cross 3d pram system in jet sport
i have a silver cross travel system and can only seem to fit the rain cover on properly when its in pram mode how do you do it when the car seat is attached
May 01, 2008 | Silver Cross 3D Stroller
Zebra MC9090-G Wireless Handheld Barcode Scanner Logo
26 people viewed this question
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
