Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidare mdl FGHB2844LF5 ice maker not working and cubed ice keeps coming out crushed
fridgetech
  • 473 Answers
SOURCE: crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid.  The solenoid is bad.  When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out.  First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down.  You can take out the ice bucket and press for cubed ice.  You should hear a loud clunk noise.  If not then you know the solenoid is not working.
Posted on Oct 11, 2007
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
aborcass
  • 2651 Answers
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
Posted on Nov 03, 2008
SOURCE: ice maker will only make crushed ice
There is a rod on the back of the ice cube bin. It goes below a plastic slide in the back of the fridge. If yoiu pull the bin out and it does not engage right, you will be 'stuck' on crush. Pull the bin part way out and see whether the rod is going below or above the horizonal rung in the rear. If it is above, rotate the metal control until it will slip under the rung.
Posted on Apr 17, 2009
SOURCE: Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Posted on Jul 28, 2009
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker only will give crushed ice. Pressing cubes changes the light but still get crushed ice.
Aug 19, 2009 | Frigidare FED300E Electric Range
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
My ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
Apr 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Crushed ice only
Oct 11, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
