Question about YouTube Videos
How do I clean the plastic filter on the interior door of my whirlpool dishwasher?
2 Suggested Answers
caleb_dan24467
  • 4 Answers
SOURCE: dishwasher leaking
get a new dish washer or call a person you know that could had this same problem :)
Posted on Feb 08, 2014
Black mold on the door and near the filter
Try to brush off with a solution of white vinegar and water.
If this does not help then
run the dishwasher empty with a Finish dishwasher cleaning kit. This can be pruchased from the super market.
http://www.finishinfo.com.au/products/additives/dishwasher-cleaner/dishwasher-cleaner/
If this does not do much then it is likely the mold is actually melted plastic from inside the pump module and needs attention.
Apr 25, 2014 | Whirlpool Dishwashers
Dishwasher leaking
Feb 08, 2014 | YouTube Videos
My Whirlpool quiet partner dishwasher seems to run
try a large cresent wrenck,or channel lock plier.ps.might place towel over plastic nut,to protect from wrench damage.
Oct 10, 2009 | Dishwashers
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
Whirlpool Dishwasher ADP 4601 , Light flashing constantly.
There is a switch attached to the door latch that may need to be replaced. (the switch is inside the door).
Feb 08, 2009 | Kitchen and Much More Dishwashers
DU943PWK won't drain
If you take the bottom panel off the DW, there is a white plastic tube that is sticking out, but attached to the motor. Turn the tube counter clockwise ( Please be sure to have wet vac ready as this tube will let water out, even if you think you have all water out, still have wet vac and towels ready) Pieces of things get stuck in that tube and make it hard to drain.. replace tube to motor after cleaning and test unit
Jan 10, 2009 | Whirlpool 24 in. DU900PCD Built-in...
Dishwasher (whirlpool quiet partner II) leaks from the door panel
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Sep 08, 2008 | Whirlpool Dishwashers
I cleaned some furnace electric filters in my Kenmore dishwasher and covered the inside with a dark stain from the dirt. I still have the stain after a month of using the dishwasher for normal...
try a product called " greased lightning". spray bottle, should work for you. apply, let set for a few minutes and scrub with plastic bristle brush . you may have to er-apply and scrub a bit, but it will remove the tar.
future referance; try this product and spray your filters clean with your garden hose.[maybe even an oven cleaner and hose]
gemerally the thngs that gather on an air filter i dont want in my
dishwasher.
Apr 07, 2008 | Dishwashers
YouTube Videos Logo
47 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
