Question about Goodman GMS90703BXA Heater
Furnace won't ignite , water dripping from exhaust fan
    Champion:
  • 305 Answers
Condensation build up with in the inducer motor....causing an air restriction
Posted on Nov 25, 2014
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
Amana furnace model amv9 has water dripping from the exhaust outlet. the exhaust doesnt seem to be clogged and the overflow for water to run into doesnt seem to be clogged. water is makign its way int
You did not say if you have a dehumidifier or air conditioner installed on this unit. If those are not installed on it then the only place moisture could be coming from is down the exhaust connection for the flue. If one or both of those items are installed then the issue is the drain trays might have debris built up that you cannot see.
Mar 23, 2014 | Heating & Cooling
Goodman furnace model gmp125-4 constant fast blinking red light on circuit board, furnace dont work, have moisture in bottom from seeping drip pan under acoil
There should be a chart pasted to the inside of the front access panel of the furnace. It will tell us what that particular blinking sequence means. Goodman isn't listing a gmp125-4 furnace so I need to assume it is a condensing gas furnace. I water has backed up into the draft inducing fan, the furnace will shut down. There is no reason for water dripping from the drain pan unless your A/C is running and the drain on the pan is plugged. Give me all the info. you can and exactly what is happening. Please look up the coded problem for me. I'll watch for your reply. I hope this is not too late to help.
Oct 07, 2013 | Heating & Cooling
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
What is the cause of no ignition to the furnace
Broken ignitor
Contaminated/dirty sensor
Tripped safety switch/rollout
Faulty/leaky/pluged exhaust fan/draft hose
Faulty exhaust/draft inducer fan assembly
Faulty exhaust fan vacuum proving switch
Open 3 amp fuse on control board
Faulty board/no power to unit
I have some video: HERE
How to clean flamesensor/electronic thermocouple: HERE
Jan 14, 2010 | Heating & Cooling
Burnham Boiler, no constant ignition.
Is there a pressure switch you can jump to see if it is defective? Is the inducer fan blowing out exhaust? You could also have a dirty pilot.
Dec 01, 2009 | Heating & Cooling
We have a dayton gas furnace model #3E463A. thought the control box was gone. got new one we furnace starts up the power goes on, fan starts no green pulsing light on control no ignition
When your furnace starts...the Ventor motor(exhaust fan) starts up....within a short time (seconds) the Pressure switch closes proving that the Fan is indeed running and the vent is not blocked...if this doesnt happen the furnace will not poweer the ignitor or fire at all....Check the vent pipe outside and look for obstructions or dirt on the screen inside the pipe...the condensate from the fuirnace may not be draining at all...due to plugged condensate drain lines...find this tube coming out of the furnace front...bottom of upper compartment usually , and pull it off the tap....if water starts coming out then your drain is plugged downstream of the furnace.
Oct 25, 2009 | Dayton Gas Furnace Heater
Water dripping from furnace while air conditioner is running.
you need to have a drip line that take away the water when the ac is on so the water does not goes into the furnace ,also check for leaky line that could causing water to leak back
Aug 20, 2009 | Heil Sound PR-40 Professional Microphone
My Carrier gas furnace (ser. 1903A41848) located in the attic, is five years old and suddenly won't light. IT cycles the fan when I cycle the power to the unit and seemingly attempts to ignite through 3...
try the fuse ,check the ignition element .do You have a drip leg on your gas supply line just before the gas pipe enters the furnace .if not your gas valve maybe folded .
Jan 04, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
29 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
