Question about Staples One Touch High Capacity Stapler
Manual for cx-3 stapler - Staples One Touch High Capacity Stapler
Will Arrow #506 staples work in an Arrow JT27 manual stapler?
Hello, there. No, 506 staples will not work in the JT27 stapler. This staple gun takes JT21 staples in 1/4-inch, 5/16-inch and 3/8-inch. Did you have any more questions about your JT27?
Oct 02, 2015 | Office Equipment & Supplies
Need a manual for a Aiwa model# CX-NAJ5OU
http://www.manualslib.com/manual/3631/Aiwa-Nsx-Aj50.html?page=3
Mar 23, 2015 | Aiwa Audio Players & Recorders
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
Bostitch electric stapler wont open
Hello, Go to this website for support number and downloading of the operators manual for the model of stapler. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
May 01, 2014 | Stanley Bostitch B8 Electric Stapler
1979 Honda CX 500 A part numbers
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1979 Honda CX500 OEM Parts
Honda Motorcycle 1979 CX500 OEM Parts Partzilla com
Honda CX500 Service Manual right click the chapter you want and save as
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-cx-owners-manuals
Jul 03, 2013 | 1979 Honda CX 500 A
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
Installing nail brad in a stapler
I have the same problem and the silly thing is I have used it. Ridiculous that you can't find a manual on it. Well, I have solved it!!!!
our problem is we open the stapler and stare straight down into the cavity. But if you angle it, you can see that there are grooves along the side which the head of the brads would hang and slide along.
1. on one side of the stapler it will say "load brad this side"
2. open the chamber and place the stapler on its side with the aforementioned side down
3 place your strand of brads in the appropriate groove and close the chamber
4 start shooting
pklew52@gmail.com
Dec 22, 2008 | Electric Stanley Tre500 Staple Gun /...
Staples One Touch High Capacity Stapler Logo
32 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
