Ricoh infoprint 1767
When I power on, it says 960 Service, Memory Error - r
  • 300 Answers
SOURCE: infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Posted on Jun 09, 2008
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: 960 service memory error - a
    The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
    Posted on Sep 10, 2010
    • 320 Answers
    SOURCE: service 960 memory error- r
    A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
    If the printer is displaying a 960 memory error.
    1. Power off the printer.
    2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
    3. Power on the printer.
    4. If the 960 error continues, the main controller/system board will probably need to be replaced.
    5. If the 960 error does not return, try printing a few documents.
    6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
    To confirm this, do the following:
    1. Turn off the printer and reinstall each SIMM one at a time.
    2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
    Posted on Nov 08, 2010
    Printtech
    • 1087 Answers
    SOURCE: 960 service memory error-a
    The printer memory is failing. RAM soldered on the system board is bad. It would be best if you contact Lexmark Technical Support for proper assistance.
    Posted on Jul 15, 2011
    Printtech
    • 1087 Answers
    SOURCE: 960 service memory error how do I solve the
    Theprinter memory is failing. RAM soldered on the system board is bad. It would bebest if you contact Lexmark Technical Support for proper assistance.
    Sir i have bought ricoh sp 210 new when i on it the mwssage displayed on it error code service code sc560
    this is mainly caused by low power voltage.. the error means bad thermosistor or blown fuse, mainly the error come from fuser unit... all what you have to do is to go to service mode of photocopier and clear the error message :press the yellow button also107 also press the cancel button which is red make sure your hand is still on the button until it pop up the service mode.. after select 1 which is copy after that select 5 which is mode after that keep on scrolling the screen until you clear memory click on it and off your machine for 5seconds
    Apr 07, 2017 | Ricoh Office Equipment & Supplies
    2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
    Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
    Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
    Already have an error code from running ePSA diagnostics?
    Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
    Mar 28, 2015 | Computers & Internet
    Ricoh error sc541
    Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
    Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
    OPTIPLEX 960 error codes 3 and 4 at startup. Solid amber light.
    "optiplex 960 error codes 3 & 4 at startup"
    Found out by myself the google suggestion to look up the Dell Diagnostics page:
    http://support.dell.com/support/edocs/systems/Op745/en/UG_en/trouble.htm
    Lights 3 & 4 means "Memory modules are detected, but a memory failure has occurred." Bingo! I didn't actually replace memory sticks, but pulled them out and put back in one by one. Only three out of four sticks were accepted. Works.
    Jun 05, 2012 | Computers & Internet
    Service 960 memory error- r for my Lexmark C532n printer
    Nov 08, 2010 | Lexmark C530dn Laser Printer
    Sep 10, 2010 | Lexmark C530dn Laser Printer
    I have always error code 546 and 960
    Error Code SC 546 is for fusing & SC 960 is for Current leakage, If u getting it regurally , change the thermistors for error code 546, & for error 960 change drum & charge roller.
    Aug 16, 2009 | Ricoh Aficio 450 Copier
    IBM infoprint 932 service printhead error
    go on line and type in
    ibm infoprint 1352 laser printer error 932
    enter
    or
    ibm 1352 infoprine error message 932
    rod
    Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
    Infoprint 1120 929 service toner sensor error code
    Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
    24 people viewed this question
    k24674
