Question about LG DLE5977 Electric Dryer
Access to gas orifice
I got the top off and the front controll panel off but can't seem to get the larger panel with door off. Something is holding it towards the bottom.
    New Friend:
  • 60 Answers
There are 2 screws just below the opening you put the clothes in that have to come out, They are behind the front door.
Posted on Dec 20, 2007
How to do a lp conversion
Some basic helpful instructions below. Really not much to it. Convert the regulator and replace the orifice. Basic instructions should come with the kit if purchased for that specific brand and model.
In my opinion, always best to buy the conversion kit at a local appliance parts store to be sure of getting all the required parts with specific instructions for the brand and model.
Basic Step By Step Instructions:
First access the burner compartment. Usually a small access door in the lower right hand or left hand corner on some brands or models. Remove access panel.
On some brands and/or models the entire front panel must be removed. Look for screws in the door frame and/or at the base of the front panel. May have screws in both locations on some machines.
Some brands and/or models the top lid must first be lifted up wards. On many of these machines there will be no screws in the door frame. Usually only two screws are the base of the machine. Some no screws anywhere external. In this case, if there are two screws at the base remove them.
Then insert a thin blade or old credit card between the top lid and front panel about two or three inches in wards from each corner. Push in wards to release the clips while lifting up wards on the top lid. Each clip can be released separately or both at once.
Once the front panel is removed or access door is opened, look to the right of the gas control valve. There will be a tiny gas shut off valve on the gas supply pipe. Turn that tiny lever so it is across the pipe. Doing so turns off the gas to the control valve.
Than remove the wire quick disconnects from the solenoids on top of the gas valve. Than loosen and remove the hex nut on the control valve to separate the gas supply pipe from the control.
That hex nut is reverse threaded. Which means the hex nut turns opposite (counter clock wise) to loosen it and clockwise to tighten it. Use a backup wrench to hold the pipe while turning that nut counter clock wise.
Once the pipe is removed, there will be two or more sheet metal screws holding down the plate the control is mounted onto. Remove those screws.
Than carefully remove the burner out enough to get to the wires attached to the flame sensor, which is attached to the burners shroud cover. Remove that wire quick disconnect also.
Than remove the entire burner as an assembly. Remove the brass or bronze orifice in the burners nozzle. Replace the orifice with an LP or NAT orifice to match the BTU rating of the burner.
BTU rating is on the manufacturers plate with the model and serial numbers, usually located in the door frame. Most dryers are either 18,000 or 22,000 Btu's. Install an LP or NAT orifice to match the rating.
Than convert the built into the gas valve regulator. By removing the cap on top of the tower and turning it over and reinstalling it. Cap should be marked "N" or "NAT" for natural gas and "L" or "LP" for propane.
Turning the towers cap over converts the regulator. Side of the cap facing you indicates the fuel type it is set for. Not all regulators are convertible in this manner. Check with any local appliance parts store.
Some gas control valves do not have regulators that are convertible while some have a set screw to turn to another position or a lever to turn to another position. Several variables are possible.
Appliance parts dealers are an excellent source for original replacement parts and conversion parts. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks when reconnecting any of a gas part.
Use the reply button to add additional information or ask additional questions. Doing so will automatically move your question to the top of the forums list of questions.
It's always advisable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection and or repairs.
Nov 02, 2012 | Amana NGD7200TW Gas Dryer
How do I get to the motor of this dryer? Do I need to get to it from the front of the dryer or the back?
On a rear control LG, from the front. Open door, remove two phillips screws at 4 and 7 O'clock positions, use putty knife to push in clips (2) holding top at front, swing top back, remove two phillips head screws holding front panel cabinet. Disconnect door switch and light plugs, tilt front panel forward and off bottom tabs, allowing sensor at bottom to be un-plugged, thus front panel now completely free of machine. 4 phillips screws hold front bulk head / front drum roller supports to cabinet. Lift up and off. Reach in and remove belt from tension pulley. Drum comes right out, allowing access to motor.
Jun 13, 2010 | LG DLG3788W Gas Dryer
Replacement of belt on dryer
Here's how to replace a belt on an GE Profile DPSE810EG4 electric dryer. There may be some minor variation for other electric GE dryers, but it shouldn't be too different. DO NOT USE THESE INSTRUCTIONS ON GAS DRYERS AS ADDITIONAL PRECAUTIONS MAY BE REQUIRED! For the electric DPSE810EG4, you will need a #2 Philips screwdriver, a flashlight, a new belt, and patience. You will also need something very close to the left front of the dryer against which you will lean the front panel. A chair, a washing machine, or a wall all work fine for this purpose.
2) Pull the dryer away from the wall and disconnect the ducting.
3) Remove the top four screws on the back panel. (These secure the control panel)
4) Open the dryer door and remove the two screws on the top of the door frame. (These secure the top panel.)
5) Pop up the front of the top panel and slide the top panel forward an inch.
6) Unlock control panel by sliding it to the right, then pull it up to detach it from the top panel.
7) Lift off the top panel and set it somewhere
8) Undo the two screws that hold the front panel.
9) Pull up a little on the front lip of the drum while hinging the front panel forwards. On the DPSE810EG4, you can set the drum down on the support member that is underneath it. (On other models you might need to put something under the drum for it to rest on.)
10) Lift the front panel off of the pins that secure its lower end, and then hinge it to the left (be careful not to yank the wires). Lean it up against something.
11) Open the access door on the back. (On the DPSE810EG4 the access door is the exaust duct itself; remove the screw that secures it and slide it out of the dryer.) Set your flashlight inside the dryer aimed so that you can see the motor and the tension pully.
12) Remove the old belt. If it's snapped in half you can just pull it out. Otherwise, reach in through the back access door with your left arm and pull it off the motor, then come around front, lift up the front of the drum a little and slide the belt off the drum.
13) Reach in through the back access door with a cloth and remove any grease blobs on back of the tension pulley axle. (This way you won't accidentally get grease on the belt during the difficult step which comes next!)
13) Install the new belt. Lift up the front of the drum a little and slide the new belt onto it (the side with the parallel grooves should be touching the drum). Reach into the back access door with your left arm. Grab the belt and pull it around the right side of the plastic tension pulley and then pull it down around the metal motor pulley. You're less likely to get your fingers stuck if you grasp the belt from the front. (The side of the belt without the parallel groves should be in contact with the tension pulley. The side of the belt with the parallel grooves should be in contact with the motor pulley.)
14) Replace the front panel. Set it down on the pins, then hinge it forward while pulling up on the front lip of the drum. Secure the two screws.
15) Make sure the drum turns OK. (If it's fairly difficult to turn, you may wish to try removing the front panel and then try putting it back so that the drum sits inside the felt strip semicircle rather than compressing it. A drum that doesn't turn well will stress the motor and cause it to pause mid-cycle.)
16) Replace the top panel. Put it on top of the dryer, insert the control panel tabs into it, and lock them by sliding the control panel to the left. Slide the top panel back and pop it down in the front. Secure the front with the two long screws and secure the control panel with the four short screws.
17) Replace the rear access door / exhaust duct. Double check that you didn't leave anything inside (including your flashlight). Slide the exhaust duct back into the dryer and secure the screw that holds it.
18) Re-attach the rest of the ducting and move the dryer back into position.
19) Plug it in and make sure it works.
Dec 21, 2009 | GE Profile Harmony DPGT750EC Electric...
How do you convert back from propane to natural gas, I already have the orifice but don't know how to put it on?
If you have the rear control dryer you posted under:
1. Unplug power to dryer.
2. remove two phillips head screws behind door, just in front of lint filter.
3. Use putty knife to push in dryer top release clips at seam with dryer front, about a inch in from each side.
4. Swing top up and remove two phillips screws holding front onto frame at very top of front panel.
5. pull front panel forward a bit and remove plug to drum light and door switch.
6. lift front panel off dryer.
7. Turn off gas shut off and remove burner / valve assembly.
8. Replace orifice and change out brass pressure regulator screw.
9. reassemble and test.
Aug 06, 2009 | LG DLG5988 Gas Dryer
I have this problem and have been told the following.
You have to take 2 Cir clips off. one on the front which is achievable by opening up the spring that holds it in place. The second one is behind the front panel.
You need to take the top off first. Undo two screws on the back top. Then you can take the top off. Then take any detergent tray our and also the front control panel. Then you gain access to some screws which hold the front panel onto the chassis.
After you take the front panel off you can apparently access the rear cir clip and spring.
once this is removed you can remove the front seal for replacement.
Jun 15, 2009 | LG Washing Machines
Motor Control Board test.
If you open the front door, you will see four screws along the inside seam. 2 where the door hinges are and 2 on the opposite side. I assume you already found the cheat sheet at the inside back of the controller. So, I'll defer to the cheat sheet for proper troubleshooting procedures... Hope this helps... Bill
May 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG Dryer DLG7188RM LP conversion back to NG
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Nov 20, 2008 | LG DLG5932W Gas Dryer
Kenmore Serios 80 Gas Dryer - Replacing Gas Valve Coils
I haven't done coils in a while, You will need to remove the top and front panel to access the coils. The top should have catches that allow you to grasp the top by the back corners and pull forward slightly releasing the catch for left an right sides, other will have to have the top console removed to reveal 3 hex screw to pull the top off. Once done get a 5/16 and remove two hex screws left and right on the inside edges holding the front on, also unplug the harness to the door switch, by now the machine should be unplugged. the coils have a flange over them held on by some phillip screws. the orifice is preset so dont mess with adjustments, they should pop out and pop in
Sep 07, 2008 | Kenmore 72802 Gas Dryer
Lg conversion to lp
remove the top, and than the control panel, and than the front will come off to expose the gas burner on the bottom right side...
Oct 25, 2007 | LG DLE5977 Electric Dryer
General Electric stove top burner does not light
whalerpaul, To get access to the gas burner valves you have to: 1.UNPLUG THE POWER CORD 2. Remove all burners 3. There are 2 screws under each burner, remove all of them and lift up the top panel 4. Remove all knobs, remove screws holding the manifold panel (two on top and four on the bottom) 5. Carefully pull out the manifold panel and remove two wires from the oven light switch, put the manifold panel on side Part number for the right front gas burner valve is WB21K12 and you can buy it here:
Jan 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
LG DLE5977 Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
