Question about TCL LE55FHDF3300ZTA 55" LED TV 1920x1080, 240 Hz, HDTV
TCL TV won't power on
We moved the tv to hang it from a bracket - when we plug it in and turn it on, no power light comes on.
3 Suggested Answers
SOURCE:
gopakumarg43
  • 76100 Answers
SOURCE: tcl l32m19 tv wont turn on woke up the other day and the light on the front was not on
Power supply regulator section [mains] to your TV should be troubleshooted. This is a skilled work.
Posted on Jun 27, 2012
  • 53162 Answers
SOURCE: tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Posted on Jan 25, 2014
In the color of black
that may be a option but we do not sell TV's or brackets
Mar 16, 2016 | Televison & Video
Why a 19' Insignia TV wont turn on?
Verify you have power at the outlet, and the TV plug. If no power check breaker. If it was moved recently to anoither location the wall outlet may be on a switched circuit, or downstream of a GFCI outlet.
Aug 20, 2014 | Insignia NS-LCD19 19 in. LCD TV
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Chrysler minivan caliper repair
If you can get the slide pins out of the brackets, buy new brackets and they should come with new slider. Wa-la, fixed. If you can't get them out you're going to need new calipers.
Mar 28, 2013 | Cars & Trucks
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
Jaguar x type brake lights stay on
the brake light switch has either moved out of the bracket just above the brake light pedal or the brake light switch itself is faulty.
look just above the brake pedal, there should be a switch on a bracket so that when you press the brake pedal the spring plunger piece of the switch moves out and the lights come on. make sure the plunger goes in when the brake pedal goes back to normal position.if the lights stay on when the plunger is pushed in the switch is faulty and needs changing, quite common. hope this helps
Apr 07, 2009 | 2003 Jaguar X-Type
Turning on
we moved in a uhaul across the US. Moving from one place to another has got nothing to do with tv operation. if it takes more time for light to come then it is a problem in brightness ckt or tube getting weak if tv is old tv. if on the whole more time means cap in power supply might be a problem good luck.
Sep 26, 2007 | Televison & Video
My t.v. been sitting for a while and now the light in the power button comes on but the t.v. itself wont turn on.
as you say it was ok before it was moved. so thre is a possibility that some parts must have gone loose while shifting .
Sep 17, 2007 | RCA TruFlat 27F520T 27" TV
TCL LE55FHDF3300ZTA 55" LED TV 1920x1080, 240 Hz, HDTV Logo
434 people viewed this question
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
robert
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
