Question about Mattel Interactive Barbie Magic Genie Bottle and CD-ROM for Windows
No game port - Mattel Interactive Barbie Magic Genie Bottle and CD-ROM for Windows
Received a comcast wireless router. and can not connect to my xbox360
1. Check for current anti-virus before doing step below.
2.Check firewall allowances or permission to be sure game is allowed
3. Try "port forwarding
4. Check the game / verify ports need for multiplayer gaming.
5. Please forward all ports UDP/ TCP To gaming computers IP address.\
6. Log in to router and place gaming computer in to DMZ.
7. When done gaming disable the game in the DMZ.
Jun 16, 2011 | Computers & Internet
Game won't load it is the only zynga game that will not load.
8. You may have to uninstall game then re-install
9. Check hard drive space to see if you have ample space to load game.
10. remove any saved game to gain more storage space.
11. check the manufactures site for the game mentioned and check to see if it is compatible with your operating system and RAM ( random access memory) requirements
Feb 16, 2011 | Computers & Internet
Hi my laptop is nec but one driver are missing standard game port having a yellow questio mark
The game port, if the laptop really has it? is not required for the computer to work normally. If you don't use the game port - it is a yellow connector - of which you can see and read more about here.
http://en.wikipedia.org/wiki/Game_port
Check if your laptop even has this port check the number of pins on the connector, you might have a wider printer port, that is not the game port.
If your laptop does not have the connector then you can right click on the game port and select Uninstall. Or Disable.
If your laptop has such a port but if you don't need to use it, right click and disable the device.
If your laptop has the port and you need to use it with a game controller? or if you are connecting a audio device into the port then please post me the exact brand and full model of the laptop and which windows it has installed and I will look into it.
Sep 21, 2010 | NEC Versa VX Notebook
All of the internet cables are connect and my ethernet cable for my xbox is connect but there is a problem signing into xbox live
Gaming router setup steps:
Jul 07, 2010 | D-Link DSL 604+ (DSL-604+) Wireless Router
I try to in a game which is online one. but it keep saying cannot connect to server. then i try other online games also they same thing.
May 17, 2010 | Linksys Wireless-G WRT54G Router
Motorola router nat not open for xbox live
Configuring the Firewall for Gaming
By default, the SBG900 firewall is disabled.
If, as recommended, you enable the firewall, refer to the game’s documentation to ensure that the necessary ports are open for use by that game.
The pre-defined SBG firewall policies affect X-Box LiveTM as follows:
LOW: XBox Live data can pass through the firewall. No user action is required.
MEDIUM or HIGH: To enable X-Box Live traffic to pass, you must configure:
• Choose Custom on the Firewall > POLICY — basic Page • UDP 88:88 and UDP/TCP 3074:3074 on the Firewall > POLICY — advanced Page
Configuring Port Triggers
Because the SBG has pre-defined port triggers for games using any of the following applications, no user action is required to enable them:
• DirectX 7 and DirectX 8 • MSN Games by Zone.com • Battle.net®
For a list of games supported by Battle.net, visit http://www.battle.net.
You may need to create custom port triggers to enable other games to operate properly. If you set custom port triggers and enable the firewall, you must customize the firewall to allow traffic through those ports.
To create custom port triggers, use the Gateway > PORT TRIGGERS — custom Page.
SB900 USER GUIDE
The motorola guide has more information relating to port triggers.
If you download the pdf file, go to page 27 for Firewall settings and Page 35 for Gaming Settings..
More indepth information is there.
Hope that helps
Mike
Sep 20, 2009 | Arris SURFboard SBG900 Wireless Router...
It works fine untail I want to play Asherons Call a MS game, firewall has locked me out, how do I shut off the firewall. tyvm Ken
What you want to do is "open ports" in your firewall. This is simple if you have admin access to your router. Find the section for "port forwarding" and add ports that your game require. Typically, there is a TCP port and a UDP port. The UDP is for broadcasting type messages to/from your fellow gamers. The TCP port is usually for the game server. Check with your game instructions -- or you can probably get the answer with a google search string of "game ports Asherons Call" and I would bet it will give you exactly the settings for your router.
Here ya go (I did the google search). It appears that it only requres the UDP port. I would open all of these unless you find out more detail that you can close some ports (never leave a port open that you don't know or don't need -- it is a hackers door to your computer).
9000 UDP Asheron's Call game
9010 UDP Asheron's Call game 9011 UDP Asheron's Call game 9012 UDP Asheron's Call game 9013 UDP Asheron's Call game
Good luck.
Apr 27, 2009 | Computers & Internet
Downloading game settings... never stops? when i try to find a game online
you have to port forward ur modem to open a port for call of duty 4 u can get port codes form infinity ward or sony by calling them its a process but it makes downloading game settings go away
Mar 03, 2009 | Activision Call of Duty 4 Modern Warfare...
Help Me pls i wan to chg the game port number to 8888. the game tuttirol ask me go thie websitesite. portforward.com so wat should i do now ?
- Game port 8888??
- No its impossible to use the port....
- It is not in range to basic ports (3000 something only)
- The 8888 is invalid...
- You can use 888....
Dec 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Problem with udp port
check whether the port numbers are opened for that particular game that you are trying to play
if not go to the router manager i.e. the home page of the router that you have and try to open the ports
Also known as port forwarding
if u dont know the ports that you want for a particular game
U can goto www.portforward.com and chek out the ports available for games...
for any further help, plz reply back
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Mattel Interactive Barbie Magic Genie Bottle and CD-ROM for Windows Logo
12 people viewed this question
Top Mattel Interactive Video Game Consoles & Games Experts
EnergeeUK
Level 1 Expert
KARTHIKEYA
Level 1 Expert
Are you a Mattel Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
