Question about Panasonic SC-HC271 iPod Dock/CD Player Micro System
My remote control fell onto the floor and now every time I try to use it it says "Remote 1" on the screen. I really need to know how to fix this because this little remote comes in handy.
  • 76 Answers
SOURCE: Remote problem.
Hi very simple to rectify,all you have to do is press and hold enter and 1 on the remote control for at least 2seconds.if this does not work use the same steps but press enter and 2.should work for you
Posted on May 16, 2007
  • 70 Answers
SOURCE: Remote Control
have you tried leaving the batteries out for an hour?
Posted on Jul 28, 2008
nandosnut
  • 112 Answers
SOURCE: Remote control does not work, Model DMR-ES15
Press ENTER and the number shown on the unit (SET 1, 2 or 3) together on the remote control for at least two seconds to restore control.
Posted on Apr 24, 2009
SOURCE: My remote control cannot work on rewind, fast forward or comerical skip. The DVD screen display SET 1.
Hello, I had the same problem and after spending a few hours reading and trying things, I found a solution. Its very simple. Power on your unit (manually) and then on your remote control push and hold at the same time"enter" and the number "1" while pointing directly to your unit and this should solve the problem. Good luck.
Posted on Jun 18, 2009
SOURCE: remote control doesnt work
The HS2 can use 3 different remote codes which you can select from the menu - you also need to tell the remote which set of codes to use. How to change the remote is explianed on page 65 of the manual - Press and hold the ENTER button and then press either 1 2 or 3 to set the remote to codes 1 2 or 3. The default is one so try that first.
Posted on Apr 08, 2010
Remote control does not respond
If the case is not damaged, remove and re install the batteries. That generally fixes problems like this. If not you will have to replace it.
Dec 25, 2013 | Hampton Bay 52 In. White Redington...
My RTI m2(?) fell off the table to the floor. The black cover dislodged and the screen also dislodged. It was still lit. When I replaced the screen the icons were lit with a pink band across the bottom of...
Sorry this remote can't be repair it is garbage,because the small display LCD screen panel it have mircro cracks and fractures in them and leaking chemicals radiation that why u able pink chemicals band across the the small display LCD screen panel.It time to buy another remote.
Sep 06, 2011 | Rti Technologies Rti T1 Remote Control
LOGITECH harmony 510 remote has locked up-
Hi! This is a really easy problem to fix. All you need to do is update the firmware of the remote!
1. Log in to the software.
2. Click 'Downloads' at the top of the screen
3. Click 'Firmware'
4. Update the remote
And it's fixed! Enjoy :)
Mar 17, 2010 | Logitech Harmony One Advanced Universal...
Tv fell on floor and now does not switch on
Take the aparts.Check all PCB boards.Might have PCB boards broken.Might even have LCD screen pannel broken,not worth repairing if LCD screen picture pannel is broken.
Mar 17, 2010 | Televison & Video
Remote was droped on floor and now doesn't work at all.
The obvious as you well know will be you need a new remote. Sorry. Thanks for using Fix Ya.
Jan 30, 2010 | DISH Network 142923 Remote Control
Phillips Universal remote control fell to floor & will not work
unscrew it and check the broken part and try to put solder in that connection
Sep 11, 2009 | Televison & Video
Logitech harmony 890 display is full of lines
Hey!
I had this same issue and Logitech gave me the troubleshooting steps below that got it working again!!!
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting.
2) Ensure you have the latest version of the Harmony Remote Software (7.7).
3) Update the firmware on the Harmony Remote. The following link shows how to complete this task:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this:
a) Remove the battery from the Harmony Remote.
b) Press and hold the power button while reinserting the battery into the Harmony Remote.
c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
I hope this helps!!!
-Kennedy
Aug 02, 2009 | Logitech Harmony 890 LCD Remote Control
Remote fell on floor, won't work replaced battery, no help
try replacing battaries, but unless you have circuit board training on how to repair broken connections i would just go get a nice universal remote and tape pillows to it so you cant break it.. .:P
http://reviews.cnet.com/best-universal-remotes/
Jun 22, 2009 | Universal Remote Control Hampton Bay...
Blank screen on the Harmony 550
I had the same problem - my kid stuck it in her mouth and then the screen stopped working. I was finally able to fix it by doing the following:
1. I took the remote apart by
a. taking out the four screws under the battery cover.
b. then, I used a small slot screwdriver as a wedge and ran it up the length of the edge of the remote while prying the top and bottom apart.
2. Once i had it apart, I took a blow dryer to it to blow out any dust and get rid of any moisture
3. I put it back together and it was in Safe mode
4. I took out a battery, held down the #2 button, and put a battery back in and got the "Update Successful" message
5. To my surprise, the remote was fixed.
Apr 12, 2008 | Logitech Harmony 550 Remote Control
No sound ,fell asleep control on floor
Try not to fall asleep on the remote again. LOL :}
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 01, 2007 | One For All URC-3021 Remote Control
Panasonic SC-HC271 iPod Dock/CD Player Micro System Logo
18 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
