Question about Funai FDRV90E DVD Recorder/VCR
No video using vcr - Funai FDRV90E DVD Recorder/VCR
My Samsung TV work fine. My RcA VHS VCR when I want to record the screen said WEAK or NO SIGNAL
VCRs use Channel three or Four to watch the tape. It is better if you use the video out on the VCR to go IN to the TV video In on a modern TV.
For record, the VCR cannot see Digital TV. You must connect the Digital TV box or satellite box Video Out to the Video In on the VCR.
Feb 21, 2012 | RCA Televison & Video
I am trying to use the Dazzle hooked up with my VCR ( I have done it before) but now the VCR is not playing the movie (can't see the video on my computer). The VCR is basic, it doesn't have an S Video
The setup should be like this.
VHS > RCA > Dazzle > Computer.
The cable must be connected at the back Audio/Video output not in the Input.
Please check also the online documentation below.
No video displayed in the Instant DVD Recorder preview window.
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=226159
Nov 27, 2011 | Pinnacle Dazzle DVD Recorder
I have a mitsubishi black dimond vcr id like to tune into a sharp tv how do i do this please
Ok, to hook it up to use as a Receiver, and TV, as a "Monitor". Using the antenna cable, plug this into the antenna IN socket on VCR. Now connect up, AV, using the Yellow, Video, Audio, is Red & White, on BOTH TV & Video. Now select an EXTERNAL INPUT on the TV. Now You Tune, and scan for "Channels" using the VCR. Find each channel, and save, now, you use the VCR remote to change channels, and the TV, is used as a "Display Monitor".
The Other way, is to just use the VCR as a "Recorder only, you plug the antenna, into the TV, now at rear of TV, you have a Video OUT, Yellow, and Stereo, Audio OUT, Red & White. Connect up the VCR to the TV using them. Now anything you View on TV, will be out put to the VCR, when you wish to record, simply press record, on Remote/VCR as desired. and it will record.
Apr 08, 2010 | Televison & Video
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
DVD-VCR connection when there's already cable & Tivo
Use the RCA connections of your TV to hook up the DVD/VCR, connect the "VIDEO OUT" of your TV to the "VIDEO IN" of the VCR and "VIDEO OUT" from your VCR to one of the video inputs of your TV. You need the double connection in case you want to record something to a VHS, otherwise, just hook up a cable from "Video OUT" of the VCR to any of the "Video IN" inputs of your TV.
Apr 23, 2008 | GoVideo Go Video DVD/VCR Combo
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Using a VCR with it.
Hi, Based on your post/description, a common installation/connection would be: 1. Ant/Cable in to the RF INput of the VCR (this is assuming that your cable TV is cable/F output and not the audio/video RCA output); 2. A short RG59 cable with F connectors at both ends should connect RF OUT of VCR to ANT/CABLE IN of TV. 3. With the VCR off, the cable would connect automatically to the TV and channel selection is thru your TV. 4. With the VCR on, The TV must be set to either 3 or 4, channel selection may be done on the VCR, TV programs can be recorded, video tapes can be played. A variation: Another would be to use the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV (assuming it's got one). The TV must be set to Video to watch cable, VCR. Channel selection would be thru the VCR. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 09, 2007 | RCA F25216BC 25" TV
VCR upconversion
check the wires, they could be bad. Or maybe your vcr head needs to be cleaned
Dec 26, 2005 | Yamaha HTR-5860 Receiver
Watching tapes on TV
To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR). Once cabling is completed, follow either of these scenarios: When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control. # When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode. # Operate the TV as you normally do to see the signal coming from the VCR. Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
Sep 06, 2005 | RCA CC-432 Camcorder
Funai FDRV90E DVD Recorder/VCR Logo
19 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
