Question about Protron PD-800 DVD Player
Says "wrong disc"
I have had the player for over a year and this just happened w/all discs.  Also, do they have a contact phone number.  Going to the website on the manual just gets you advertising.  Thank you.
  • 4 more comments
  • Anonymous Nov 18, 2007
    our too. for some reason it will play pg movies but not rated R. we were tring to watch 28 weeks later, that won't play but any disney movie will...grrr
  • lynardh Dec 23, 2007
    will not play any dvd, says wrong disc. is not dirty
  • srfzap Jan 25, 2008
    same exact problem as queek. wrong disc error. will get same with any dvd or cd. also same result at website prosonicusa.net srfzap
  • Anonymous Feb 26, 2008
    all dvd says wrong disc
  • dancingboots Mar 01, 2008
    I have the same problem with my dvd player saying wrong dics no matter what type of dvd I try to play. Other than cleaning the player, I don't know what else to do and there is nothing in the manual that covers this.
    dundalkboxers@netzero.net
  • GLO56 Apr 16, 2008
    YES ITS SAID THAT IS THE WRONG DISC FOR ANY THING I PUT
After looking around i found 2 #s for protron tech support
1 888 257 8899 / 1 888 327 8899
after speaking to them on wrong disc error they said try taking disc out turn off unit and unplug for 20 - 40 mins this would reset it they said.
this did not work. after calling back they suggested a disc cleaner or take the uint to a local tech to be fixed.
as this unit only cost under 60$ i figured i would try some windex on a disc wipe "some" away insert disc . low and behold after a few tries most of my dvds now play again.
as i dont recommend this for fear it could result in other issues you might try the #s or first recomendation.
srfzap
Posted on Jan 26, 2008
    Problem Solver:
  • 5 Answers
This problem can often be caused by the DVD player software thinking it is in a region different than your discs. (DVD discs are often encoded with 'region codes' meaning a disc purchased in Asia will not work in a player expecting to see North American discs)
What can happen is the player 'forgets' where it is, and your regioned discs won't play any longer (region free discs should continue to work as will audio CDs ....)
A power surge, random cosmic ray or similar flakiness can cause a player to 'forget' what region it was designed for ....
If that is what has happened you need to 'reset' the region code.
Altho I can diagnose this, I have NO CLUE as to how to do this with a Protron PD-800 DVD player. Anyone out there know how to reset the region codes for this (or generically for a DVD player?)
Thanks!! //cheapz
Posted on Jan 22, 2008
Coby portable dvd player model tf-dvd1021...load dvd into player, then "wrong disc" comes up and player just stops! Won't play dvd after that.
Check and replace the Laser Pick-up unit of the DVD player. It is weak. Contact any service technician. This work cannot be done by a user. It is somewhat skilled one.
Visit this site. Sometimes, it might help you. Pull up older posts
Jan 28, 2017 | Coby Televison & Video
Can't play CD's
The laser lens in your player might be dirty or failing.
Try the following solutions:
Clean the laser lens with a DVD player lense cleaning disc.
Lense cleaning discs are available at many electronics retail store and websites.
Jun 15, 2008 | Philips FWC399 CD Shelf System
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
Doesn't play blu-ray discs all the way through but will play dvds. What is going wrong? Usually will only play one chapter of a blu-ray and then it will start scanning forward or pausing.
You should try this: go to www.sonystyle.com then click on "support" then click on "software/drivers" then enter your model number in the box and follow the rest of the instructions to download and install/update the firmware in your BluRay player, this may fix the problem and it may not but give it a try, if this doesn't fix it contact Sony's tech line and they will help you.
Good Luck !
Apr 21, 2010 | Sony BDP-S300 Blu-Ray Disc Player
DVD player locks up, won't read discs
its about time you get a new DVD Player...What type is it??? if it is a expensive one it is probably worth getting repaired but if it is a cheapy..then throw it away coz its not even worth looking at...there are the biggest pain to fix!! Best solution is to buy a new one!
Aug 11, 2009 | Televison & Video
TV won't playback DVD-RW Disc recorded on another TV.
THE PLAYER IN THIS MODEL DOES NOT READ DVD+ OR DVD- OR DVD RW DISKS ITS NOT GOING TO HAPPEN! CHEAP PLAYER INSIDE WILL ONLY PLAY STORE BOUGHT DVDS
Nov 23, 2008 | TruTech PLV16320 Television
Wrong disc
Manually slide the laser (in its bed) along its track toward the center of the player. Try this a few times, restart as needed. I just got this advice from another poster and am happy not to spring for repair costs now, or another cheaply made substitute.
Jun 10, 2008 | Coby TF-DVD7005 Portable DVD Player
Lg rh7500 dvd recorder
ive only seen that either if the laser is dirty, or the cd is in bad quality, such as scratched but most likely because it cant read the disc well
Nov 21, 2007 | Televison & Video
Wrong disc?
for god sake, i want to talk to customer support... you guys don't even have a 1-800 number posted....disgusting.....I am very upset with your cheap product...i guess i won't be buying protron dvd players from now on.....Whenever I put a dvd, it keeps on saying wrond disc and makes a wierd sound....please solve my problem and also give me your customer support phone number
Nicky Patel
Oct 22, 2007 | Protron PD-800 DVD Player
Protron PD-800 DVD Player Logo
284 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
