Question about Sharp Office Equipment & Supplies
Sharp decimal rounding - Sharp Office Equipment & Supplies
2 Suggested Answers
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
What does the 5/4 and F mean on the display screen?
F is for floating decimal. If you do a calculation, it will present the results without rounding. For example, 1/2 would be displayed as 0.5, whereas 1/8 would be displayed as 0.125.
The 5/4 rounds the results. For example, if the number of decimals is set to 0, 1/2 is 1. Similarly, if the number of decimals is set to 2, 1/8 is 1.3.
Good luck,
Paul
http://support.casio.com/en/support/answer.php?rgn=5&cid=004001001004&qid=32&num=1
May 21, 2016 | Sharp EL-1701C Calculator
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
Sharp EL- M332 caluclator- have a 'O' along top line- can't seem to get rid of it- must have accidentally selected something. It is not showing any decimals.
Hold (C.CE) then whilst holding it press (M+) for approximately a second and it will move one place along in the three settings (F, 2 and 0) F shows full decimals, 2 shows 2 decimal places and 0 as yours is set to now round to the nearest whole number. I have just been sat at my desk trying to work this out as my calculator was too set to '0'. Took me reading the 'DEC DET' text with lines pointing at 'M+' and 'C.CE' to finally crack it!
Hope this helps.
Apr 04, 2011 | Sharp ELM332BBL Calculator
I have a SHARP EL-738 financial calculator. How do I set the decimal rounding to more than 2 decimal.
Press SETUP 0 0 then select the desired number of digits to the right of the decimal point.
Aug 12, 2010 | Office Equipment & Supplies
How do you change the number of decimal places?
• Press [2nd] [MODE] and scroll to FLOAT.
• Press the right arrow key until the number of decimal places needed is highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2 should be highlighted. All answers will then be rounded to 2 decimal places.
• Press [2nd] [QUIT] to return to the home screen.
Mar 17, 2010 | Sharp EL-738 Scientific Calculator
Sharp ELSIMATE EL-240SA - how do you stop this calculator from rounding up to whole numbers? I generally need two decimal places. Gordon Gillies
From the manual:
Jul 06, 2009 | Sharp Office Equipment & Supplies
I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Nov 11, 2008 | Sharp EL-531VB Calculator
Reset to factory settings
remove battery and return it back this make reset-decimal places can be adjust with decimal switch.
Dec 21, 2007 | Sharp EL-240SB Calculator
16 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
