First All Check: 1.Confirm whether same sim card is working in other h.s or not. 2.Make sure the sim slot is o.k. only try these two. 3.If all the above steps fails, check the SIM card connector pins for damage. if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD. u can make it jumper mean u can fix this prob with out sim card is for this contact. 5.take sim connector slight up by pin then cheak by inserting sim. 6.hot air gun on sim i.c. then cheak it. Last Option: IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service & Sim Office and Get the Duplicate Sim Same Your No From Office Oprator Problem will Solved Quickly
When you remove the battery cover, the SIM card is in the middle of the phone, sticking out just in front of the battery. You just slide the SIM card out. If you don't see it when you remove the battery cover, you are missing it because the phone definitely uses one.
Take the battery and sim card out (if you have a sim). Leave them out
for awhile. Then put the battery and sim card back in your phone. See
if your phone turns on. If not, contact warranty exchange.
Try rigorously cleaning the sim card and phone connections (also battery connections - after reading forums the batteries on V3's are often to blame for their problems) with a cotton bud then leave the phone off without the sim card in it and charge it overnight. Then put in the sim card and turn the phone on. This might help. My V3 often says Insert SIM and it is very annoying so i'm getting rid of it but those methods have worked for me.
Hi, first go here: http://www.somelifeblog.com/2007/03/motorola-razr-v3-how-to-remove-battery.html to remove the back and the battery from the phone, then go here:http://www.somelifeblog.com/2007/03/motorola-razr-v3-how-to-remove-sim-card.html
