Question about Cadet Manufacturing CT402 Electric Heater
Ct 402 will not heat - Cadet Manufacturing CT402 Electric Heater
The sun is so harsh on wood windowsills they crack in a couple of years and have to be repainted. Someone told me to use aluminum oil based paint on them prior to painting them. All I found is 402...
Usually when you have cracking on your windows, there's several variables including sunlight. One of the biggest problems is using the incorrect primer or a cheap paint. Contrary to what many believe, a primer that dries extremely hard is not ideal for exterior surfaces. Wood expands and contracts with heat, cold and moisture. A high quality latex primer, topped with a high quality exterior latex paint will give you the best results. It allows for flexibility but offers great protection. Some prefer an oil/alkyd based primer. This is fine as long as it's a slow drying primer. The quick drying primers have hardeners in them that don't flex well. Be sure to remove any loose and flaking paint before you prime them. There are places where you can cut corners with painting. I wouldn't do it on exterior paint. One last thing to be aware of- be sure it's not lead paint you're working with. That changes everything.
Oct 20, 2013 | Rustoleum Rust-Oleum 1030-402 402 Green...
I NEED THE CODE TO AN LG LCD TV FOR THE BRIGHTSTAR BR100Z
here is a list of tv codes hope this helps
Admiral 500, 614 , 902, 615, 610, 501
Advent 911, 932, 933
Aiko 900
Akai 601, 903, 922
AOC 601, 617, 103
Apex 000, 618, 604
Audiovox 100, 901, 900, 101
Belcor 617
Bell&Howell 620, 611
Bradford 901
Brockwood 617
Broksonic 902, 614
Candle 601, 619
Celebrity 605
Changhong 618
Citizen 903, 601, 619, 900
Clairtone 103
Concerto 619
Contec 901, 103
Craig 901
Crosley 303, 301
Crown 901
Curtis Mathes 400, 301, 620, 100, 500,
903, 621, 606, 619, 611,
603, 102, 402, 401, 405
CXC 901
Daewoo 100, 617, 900, 101
Daytron 617
Dumont 700, 617
Durabrand 902, 901, 201, 614, 615, 914, 918
Dynex 614
Electroband 605, 103
Emerson 620, 902, 614, 901, 200, 201
607, 617, 615, 602, 103, 101
Envision 601
ESA 901, 201, 601, 903
Fisher 620, 801
Fujitsu 615, 300
Funai 901, 615, 201
Futuretec 901
GE 400, 202, 100, 200, 607
608, 802, 402, 401, 405
Gibralter 700, 601, 617
GoldStar 601, 607, 617, 619
Grundy 901, 615
Haier 914, 918
Hallmark 607
Harvard 901
Hitachi 606, 619, 611, 005, 916
ILO 921, 925, 609
Infinity 301
Inteq 700
Insignia 614, 303, 201,301, 909, 919, 920, 934
JBL 301, 000, 604, 618
JCB 605
JC Penny 400, 609, 202, 903, 601, 607,
608, 617, 800, 402, 405
JVC 701
KEC 901
Kenwood 601, 617
KLH 618
KTV 901, 601, 103
Konka 904, 001, 304, 002, 003
LG 619, 910, 700
Logik 611
Luxman 619
LXI 400, 301, 620, 609, 607, 402
Magnavox 301,302, 303, 601, 615, 617, 803,
905, 906, 907, 908, 909
Majestic 611
Marantz 301, 601
Matsushita 004
Megatron 607, 606
MEI 103
Memorex 620, 004, 614, 104, 607, 615, 611
MGA 104, 601, 607, 617, 500
Midland 400, 700, 202, 402
Minutz 608
Mitsubishi 500, 104, 607, 617, 601
Motorola 500, 802
MTC 903, 601, 617, 619, 103
Multitech 901
NAD 609, 607, 603
NEC 601, 617, 619
Nikko 601, 607, 900
Noshi 800
NTC 900
Olevia 923
Onwa 901
Optimus 620, 004, 603
Optonica 500, 610
Orion 902, 614, 615
Panasonic 004, 202, 802, 610
Philco 301, 614, 601, 606, 617
Philips 301,302, 303, 601, 615, 617, 803,
Pilot 601, 617
Pioneer 603, 600
Polaroid 400, 910, 913, 915, 917, 920
Portland 617, 900
Prism 202
Proscan 400, 402
Proton 607, 102
Pulsar 700, 617
Quasar 004, 202, 610, 802
RadioShack 400, 620, 610, 901, 621
607, 617, 619, 402
Realistic 620, 610, 901, 601, 607, 617,619
RCA 400, 617, 800, 612, 600
402, 403, 401, 404, 405, 623
Rhapsody 103
Roomconx 614, 615, 902, 924
Runco 700, 601, 616
Sampo 601
Samsung 903, 601, 607, 617, 619, 930
Sansui 614, 902, 615
Sanyo 620, 801, 931
Scotch 607
Scott 902, 901, 607, 617, 615
Sears 400, 301, 620, 609, 607
615, 622, 801, 201, 402
Sharp 500, 610, 501, 929
Sharp (LCD) 912, 929
Shogun 617
Signature 611
Simpson 803
Sony 605
Soundesign 901, 607, 615
Squareview 201
SSS 901, 617
Starlite 901
Supreme 605
Sylvania 301, 601, 201, 901
Symphonic 901, 201
Tandy 500
Tatung 802
Technics 004, 202
Techwood 202, 619
Teknika 301, 901, 104, 605, 617
615, 619, 611, 900
TMK 607, 619, 602
Toshiba 620, 609, 903, 613
Trutech 101
Victor 701
Vidtech 607, 617
Vizio 927
Wards 301, 610, 601, 607, 608
617, 615, 619, 611
Westinghouse 926, 928
White Westinghouse 614, 101, 605
Yamaha 601, 617
Zenith 700, 614, 611, 900, 619
Feb 25, 2013 | Universal Remote Control Remote Control
What does the ic 406 and. The ps401 and 402 look like or where could I find them in my sony projection tv. The red light is blinking 8 times
Ic 406 is the audio amp ic. It is on the signal board, that's the one with the tuner on it. It's mounted on an aluminum heat sink with fins on it. It's all by itself. 401 & 402 are small pico fuses normally black in color and you can't tell by looking at them if they are bad. You have to use a continuity checker or an ohm meter. The signal board board does not have the transformer with the red leads coming out of it.
Dec 27, 2010 | Sony KP-46WT500 46" Rear Projection...
I have a cadet model ct 402 that one of the heaters is blowing cold. How hard is it to replaace the element of do I replaced the unit. Thanks, j
I have had to replace two of them. If you have a basic understanding of electricity and identify each wire it's easy to do. The elements don't seem to stand up. I'm going to change heaters if it happens again. Good luck.
Sep 24, 2010 | Heating & Cooling
I need a replacement screen for my Archos 402 Gmini
Broke the Back on my Archos Gmini 402 20GB and if anyone has one for sale broken i am willing to buy it from them for the parts as all i need is the rear panel and the screws for the Rear panel.
Jan 26, 2009 | Archos Gmini 402 Digital Media Player
Sew Pro QuickStitch SP-402 Manual
i have found where you can get this instructional manual for free. Go to http://www.topinnovations.com/products/sew/SP-402/SP-402.html. if you are not looking for the SP-402 they also have other sewing machine manuals at this web site and you can get the address http://www.topinnovations.com and type in the search for what you want. I hope you all like this and it helps you in time to come.
BonnieLou
Nov 21, 2007 | Sew Pro QuickStitch SP-402 Mechanical...
Freezes on start up
If you have problems with the file system on your Gmini? 402 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini? 402. ? Quit all running applications. ? Properly connect the Gmini? 402 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini? 402. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini? 402 from your computer. Try it now and see if makes any difference,
May 22, 2007 | Archos Gmini 402 Digital Media Player
Cadet Manufacturing CT402 Electric Heater Logo
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
