Question about Elna Quilter's Dream 6003Q
Bobbin winding is stuck on my computer
After i threaded the bobbin the bobbin winding stays on the computer
  • 323 Answers
SOURCE: Bobbin winding
On the top left side of your machine is a round thread guide which is supposed to create tension and guide the thread. Sometimes the thread comes out of this thread guide and causes the problems you are experiencing. Wrap the thread around this guide one time and you should have your problem resolved.
sewman7
Posted on Jul 09, 2008
Sewtech1
  • 69 Answers
SOURCE: The bobbin winder won't turn to wind the thread onto the bobbin
your bob winder unit has run dry and needs oil to be worked into it
Posted on May 01, 2009
  • 1116 Answers
SOURCE: Bobbin Elna 500?
I found listings for two different Elna 500 sewing machines.
You can download or view the information that pertains to your model - http://safemanuals.com/reference-ELNA/1
The site will give you the security code to enter for the download.
Posted on Apr 08, 2010
Tally Girl
  • 1129 Answers
SOURCE: The bobbin winds really loose
You need to keep tension on the thread spool as you wind the bobbin to avoid this from happening. Also, is there a little tension device to take the thread around between the spool and the bobbin winder? Some machines have a little silver button tensioner purely for bobbin winding to keep the thread flowing smoothly.
But I always do the following anyway just to ensure a smooth bobbin. Take the thread from your spool, through the eyelet or tensioner, then back to the bobbin and put the tail end up through a hole in the top of the bobbin. Now put the bobbin onto the winder and click it against the stop. Place the curved handle of a pair of scissors onto the top of the thread spool and apply some gentle pressure to stop the spool from bouncing and jumping while winding off. Keep doing this through the winding process.
Start the bobbin winding mechanisim, its a button on my Janome 6500, yours might be a little different. HOLD the thread tail until you've got coverage over the whole bobbin area catching the starting point. Stop, trim the thread tail off top of the bobbin with scissors, then restart winding again. Watch as the thread winds and give it a nudge with your finger tip to the top or bottom so the bobbin winds evenly across the whole spool's width.
Best analogy here is when you wind the garden hose onto the reel, if it goes on all over the place you never get the whole length on neatly, but if you wind it on neatly in an even tight coil across the spool, then back again, then repeat, you get a tidy hose. But just wind madly, it all builds up in the middle, you can't get it all onto the reel, and it won't pull out nicely next time you need it. Same thing with your SM thread.
Polyester and silky embroidery threads will be worse too as they are silky, so if the thread hasn't been wound on smoothly and under tension, then it will "collapse" with gravity, then when you use the bobbin, the thread is going to be caught on itself, will feed unevenly and be stretched, then loose, giving you less than perfect stitch tension.
My other bobbin tip is store the bobbins in a plastic bobbin tray so they are lying on their edges and under a cover. Keeps them neater and they are less likely to unwind stray threads around your sewing cabinet if you store them on the spool pins build onto the cabinet door - and it keeps the thread dust free. But I do not keep thread on bobbins for long, prefer to wind a fresh one off a new spool when I start a project and can usually complete a garment with a 3/4 filled bobbin, use the remaining few metres for handsewing, then junk the rest. Then I put the thread spool that is left back into a sealed takeway container to keep it away from UV, dust and moisture.
I hope this assists you with your machine and certainly if this doesn't resolve the bobbin issues, then I'd suggest you visit your dealer and ask them to demonstrate the technique on your machine to see if there is a technical issue with it.
Posted on Apr 11, 2011
Tally Girl
  • 1129 Answers
SOURCE: My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Posted on Aug 02, 2011
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
Unable to remove bobbin from bobbin threader till almost all thread removed. Viking 1+
You could stop the bobbin filling process just before the bobbin is "full."
Most machines have a finger that rides against the area being filled; maybe this is bent?
Feb 22, 2015 | Husqvarna Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin stich is uneven and a tangled mess
you can dowload a manual from the singer website http://www.singerco.com/accessories/manuals.html
If the bottom stitching is uneven, its mostly the top thread not under tension correctly so check the tension dial and the threading up from the thread spool to the needle.
Also, review how you wind a bobbin, you want a nice smooth wind, not twisting or uneven build across the bobbin. The manual for this machine is pretty brief on this but bobbin winding is crucial to getting a good even flow from the bobbin when stitching seams. You want to wind thread smoothly onto the bobbin, across the full width of it, not just mainly in the middle. Give the thread a nudge with your finger tip to fill top and bottom as it winds.
Also, ensure the thread goes through the bobbin tension disc on top of the machine, and even then, use your scissors handle to put some downward gentle pressure onto the thread spool you are winding off so it doesn't jump or bounce as you wind. Wind the bobbin to 3/4 full, then stop.
And lastly, load the bobbin correctly following the manual directions, make sure it is turning the right way in the bobbin case. Also look at page 16, it shows the "dangle" test where you can check the tension on the bobbin case is right, you should be able to dangle the bobbin by the thread tail and it should "stay" but you should be able to pull on it to release thread too. Adjust the little tension screw in minute increments to get this right. Bobbin case tension springs can fail or break too, so check this out.
Hope this helps you; it is my experience that 90% of machine issues are caused by blunt or wrong sized needles, wrong threading, no tension or incorrect tension or lack of maintenance.
Apr 16, 2011 | White Sewing 1888 Mechanical Sewing...
Bobbin stuck on winder
Sounds like you need to remove some thread off the bobbin to get the pressure off. Sometimes if you wind too fast or you have a poor quality thread, the thread will stretch as it winds and causes to bobbin to compress onto the winder shaft.
Good Luck!
Jun 15, 2010 | Husqvarna Lily 540 and 550
Husqvarna viking 770 bobbin sticks on rewind post
I believe that you mean the bobbin is stuck on the winder. If so, take the thread off of it and it will come off easily.
Wind your bobbin at about 1/2 speed until it gets 1/4 to 1/2 full, then you can speed up. Also, make sure that the presser foot is up if winding with thread through the needle. Always make sure that thread feeds smoothly to the bobbin.
The bobbins stick when you have too much tension on the thread or wind too quickly. They will actually squeeze down on the bobbin winder post. Removing thread generally solves the problem.
Jul 06, 2009 | Husqvarna Viking 1
Viking Sacndinavian 200 - i was refilling my bobbin and now it is stuck. I can not get if off. not sure what happened or what to do
Take the thread off of the bobbin and it will come right off. Generally this is caused by either winding the bobbin too fast or having too much tension on the thread.
Either way, take off the thread and it will come off.
Thread the machine in accordance with the owner's manual when winding a bobbin and wind at 1/2 speed and you should be fine.
Aug 24, 2008 | Husqvarna Viking 1
Sewing Machines Logo
19 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
