10 fact about neptune - Washing Machines
What is neptune made of
Neptune the planet, is made of ice, rock, gases and liquids. The atmosphere is 85% hydrogen, 13% helium, 2% methane. The methane absorbs red light making the atmosphere appear blue. There are trace amounts of ammonia and water ice in the atmosphere. The core is made of iron,nickle and silicates and is very hot, thousands of degrees, in fact. Beneath the atmosphere is a mantle made of liquid. That liquid is ammonia, methane and water. It is dense. The planet actually radiates twice as much heat as it receives from the sun due to the temperature at its core. Temperature of the atmosphere may be minus 218 degrees C. Thus you have atronomers referring to it as an icy planet.
Oct 21, 2017 | Neptune Washing Machines
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Name the moons of neptune
On July 15, a 14th moon of Neptune, provisionally called S/2004 N 1, was announced.
Outwards from Neptune, the inner moons are Naiad, Thalassa, Despina, Galatea, Larissa, S/2004 N 1 and Proteus.Next outward from Neptune, Triton is one of four moons in the solar system known to have an atmosphere. The thin nitrogen haze is thought to have evaporated off of the frozen surface.After Triton comes Nereid. Much further out than Nereid orbit five outer moons, Halimede, Sao, Laomedeia, Neso and Psmathe.
http://www.space.com/21977-neptune-moons-planet-facts-infographic.html
Feb 03, 2015 | Optics
I neeed help finding candy facts for school !!!!
Alright. so you didn't have any specifications, here are a few links that might be useful:
http://www.skipscandycorner.com/Facts.htm
http://www.chevroncars.com/learn/food-recipes/candy-facts
http://www.fooducate.com/blog/2010/10/31/10-fun-and-weird-candy-facts-happy-halloween/
May 12, 2011 | Computers & Internet
I have a maytag front load neptune. The door is locked but does not show that it is lock on the panel, it will not wash but will not open either, how can I get the door open?
they seem to have a issue with the doors on theses machines whirlpool owns maytag now
they were sued very bad for theses issue
The older Neptunes, such as the 2000 Stackers, MAH3000, MAH4000 and the MAH5500A series had some issues which I am sure Maytag has corrected these issues in the newer machines...
There are thousands who have been burnt by the door latch wax motor failure. What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11) and a triac (Q6).
However, if Neptune owners know to replace the door latch wax motor they can prevent the control board failure from happening. Please tell everyone you know about this important fact.
The older Neptune's also have a couple additional issues such as the moldy door boot and the reliability of the motor / motor control board. All three of these issues were involved in the class action lawsuit a couple of years ago. See http://www.neptunewaxmotor.com for more Neptune information.
In addition, I just now started offering a bearing and seal kit for the Neptunes because when the bearings fail Maytag wants you to replace the whole outer tub for a service quote of around $900 or so. Why replace the whole outer tub? Just replace the worn bearings and 12002022 seal... See http://www.neptunebearing.com for the Neptune bearing kit information.
The older Neptunes run great once you take care of some small details...
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer doesn't stay running. filled with water, then shut down then filled some more and now stuck doing nothing. If push start button if runs for about 5 seconds then shuts off. 10 years old.
For being 10 years old...I'd say R.I.P Neptune. A 10-year-old dryer is going to cost you more in repairs than the cost of a new machine! And even if it is cheap enough to fix, the parts may be no longer available. I used to work at the Harrisburg PA Sears Parts/Service Center...trust me...I know.
Jan 29, 2010 | Maytag Neptune MAH6500A Front Load Washer
Blown bulb in Maytag Neptune Drying center in tumbler section
1-800-688-9900 OR WWW.MAYTAG.COM, THIS SHOULD HELP YOU OUT.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune,shuts down within 10 seconds after start button is pushed
If it has worked for a year and your able to choose different cycles with the same result. It seems to functions with one common element failing. If the control unit cant detect how full the machine is with water it will shut down. Sounds like a water problem steming from your pressure switch. Not sure which model you have but usually it will sit on the water pump or under the console with a clear hose if under the console. If so a quick test of attaching an ohm meter set on continuity then blowing lightly to see if under pressure the switch reacts by closing if it doesnt then the switch is bad.
Sep 16, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
