Question about Microsoft Standard Wireless Optical Mouse
IntelliPoint driver How do I get the computer to recognize it?
Is microsoft intellipoint needed in startup. Trying to figure out what program is running in the backgrond when I shut down the system. I close out all running applications before shutting down.
Intellipoint is used for your Microsoft mouse. You can disable it and use the generic mouse drivers, but you won't be able to use the mouse's special buttons and extra functions.
Feb 17, 2011 | Microsoft Windows 7 Professional for PC
My wireless mouse and keyboard have been working fien. When i switched on today, I got a "usb device not recognised" and they no longer funtion. ihave tried to check for new drivers, restarted...
I had that problem when I reinstalled my OS. I went to the Microsoft website and searched for the software for the keyboard and mouse, Intellipoint, for the mouse I think. It comes as a package for the mouse and kb based on the model you have. Pretty simple to find. Just load it and it should install without a problem and be recognized by PC. If your USB drivers are OK, this should be all you need to do.
Dec 11, 2010 | Microsoft Wireless Optical Mouse USB...
Changed batters in mouse. Now doesn't work. No
1.Make sure that you have inserted both the required batteries (New batteries) into the wireless pointing device and that they are positioned in the correct direction.
2. Resync the mouse.
3.If you do not have the resync button follow the next step
4.Test the device on a different computer
If the issue continues to occur, test the mouse on a different computer in a different environment. If you can replicate the problem in a different environment, you may have a defective device. If this is the case, see the "More Information" section for information about how to contact Microsoft Supplemental Parts to obtain a replacement device.
5.Test the mouse by using the Mousinfo diagnostic tool
The Mousinfo diagnostic tool is installed together with the IntelliPoint software. If you do not have this software, you cannot open the tool.
To install the IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
6.To open the Mousinfo tool, follow these steps.
* Windows Vista or Windows 7
1. Click Start
Collapse this imageExpand this image
Start button
2. Click All Programs.
3. Click Accessories.
4. Click Run.
5. In the Open box, type mousinfo, and then click OK.
* Windows XP
1. Click Start.
2. Click Run.
3. In the Open box, type mousinfo.
4. Click OK.
6.Click the mouse buttons to check whether the button clicks are recognized as UP and DOWN commands in the tool. If the mouse buttons are not recognized, you may have a defective device. If this is the case, see the "More Information" section for information about how to contact Microsoft Supplemental Parts to obtain a replacement device. However, the best way to determine whether the device is defective or damaged is to try the device on a different computer.
7.Uninstall any conflicting mouse software
If you have any other mouse software that is installed, such as Logitech or touchpad software, that software may conflict with the IntelliMouse software. To uninstall the other software, follow the appropriate steps for your version of Windows.
8. 1.
Open Programs and Features in Control Panel. To do this, follow these steps:
1. Click Start
Start button
2. In the Start Search box, type appwiz.cpl.
3. Press ENTER.
User Account Control permission
If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
* Windows XP or earlier versions of Windows
Open Add or Remove Programs in Control Panel. To do this, follow these steps:
1. Click Start.
2. Click Run.
3. Type appwiz.cpl.
4. Click OK.
2. Find any other mouse software in this list, and follow the instructions to remove the software.
3. Restart the computer.
9.If the issue continues to occur-Remove and reinstall the IntelliPoint software
1. View the list of programs that are installed on the computer. To do this, follow the appropriate steps for your version of Windows.
1. Click Start
Start button
3. Press ENTER.
1. Click Start.
2. Click Run.
3. Type appwiz.cpl.
4. Click OK.
2. Remove Microsoft IntelliPoint. To do this, follow the appropriate steps for your version of Windows.
1. Click Microsoft IntelliPoint.
2. Click Uninstall/Change.
3. Click Yes to confirm that you want to remove the program.
* Windows XP
2. Click Add/Remove.
3. Click Finish.
4. Click OK.
4. Download and install the latest version of the IntelliPoint software. To do this, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK (http://www.microsoft.com/hardware/download/download.aspx?category=MK)
Mar 21, 2010 | Logitech 3-Button Cordless Optical Scroll...
Quick instruction to install leeds asi/66887 wireless mouse
You need installation disc, if you have lost the CD, than go to this site Driver Update Software for XP Vista 7 8 and download their update tool. I hope I helped.
Micky
Feb 12, 2010 | Microsoft Wireless Notebook Optical Mouse...
Strange situation that I am getting annoyed with. Here's what the deal is: I have a Wireless MS Intellimouse Explorer which actually works fine but, the intellipoint software (nor device manager) does...
Sounds like you need to update your mouse's driver, you will find the intellimouse 6.3 driver for Windows XP at the link below "IntelliPoint 6.3 32-bit for Windows XP".
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=MK&type=Mouse&name=m_imobt&os=XPSP2&lang=en
Feb 22, 2009 | Microsoft Wireless IntelliMouse Explorer
Microsoft USB notebook optical mouse 3000 intellipoint
when u purchased ur mouse,u must have got the drivers with it,,its in the box,,its a cd,,so u inly have to put that in ur cd palyer and install it..as simple as that..
Apr 06, 2008 | Microsoft IntelliMouse 3.0
Cannot get laptop to recognize logitech optical mouse
systemdude, you can download MouseWare HERE. It does not use SetPoint software. The picture of the mouse may not match your mouse, but its the same software.
anovice, you can download the SetPoint4.40 software for your LX7 mouse HERE.
neri59, you can download the driver for your mouse HERE
Cheers!
Mar 21, 2008 | Computers & Internet
Microsoft Wireless Optical Desktop 4000
Dear Nealteresa:
Please click on the link below and download the drivers for Microsoft Wireless Optical Desktop 4000 and select IntelliPoint 6.2 (32bit) for Windows Vista.
http://www.microsoft.com/hardware/mouseandkeyboard/DownloadResult.aspx?prod=m_wod4000&os=WVista_32&lang=en&driverVersion=IntelliPoint%206.2%20(32bit)%20for%20Windows%20Vista Or you can also customize by selecting product and operating system. http://www.microsoft.com/hardware/mouseandkeyboard/download.mspx Note: However the Microsoft Wireless Optical Desktop should work with the native drivers of operating system.
Regards,
Mohammed.
Dec 08, 2007 | Microsoft Wireless Laser Desktop 4000...
Microsoft Standard Wireless Optical Mouse Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
