Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Cuisinart Grind and Brew. The grinder is not grinding the beans
What could be creating this problem? What can I do to fix it?
SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
Actually, I've never had any problems with my grinder. Got it for a very low price at Costco about 2 years ago. The switch has never failed to function and I've often slid the switch over to the left to stop the grinding before the designated time (I was in a hurry for my coffee) , but this hasn't seemed to negatively effect the function of the switch. It just keeps working.
Posted on Sep 20, 2008
SOURCE: cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Posted on Oct 07, 2008
SOURCE: cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the Cuisinart.ca website, you can select the product you are looking for and download the instruction booklet from the product page.
http://www.cuisinart.ca/en/pdf/ibs/DGB-600BCC_en.pdf
Hope that helps!
Posted on Oct 17, 2008
SOURCE: The grinder does not work
I just sent an email to the following address: customerservice@cuisinart.com
explaining the problem. I'll repost here when I hear back.
Posted on Oct 28, 2008
SOURCE: Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Posted on Apr 04, 2009
What is stripping the young leaves on my runner beans
This is a problem with your Cuisinart Grind & Brew Coffeemaker? This product uses roasted whole bean coffee. Why in the world would coffee beans have leaves attached? Makes no sense.
Jun 16, 2014 | Cuisinart Thermal DGB-600 Grinder
Grinder on Cuisinart Grind and brew does not work anymore.
Have you ever heard of the saying: A penny on the rail will prevent a locomotive from starting, but a locomotive will run over the same penny at speed.
This is what I think you have here. A coffee bean is preventing the blades in the grinder from grinding. Just like a garbage disposal, turn the blades (UNPLUG THE MACHINE) backwards to free up the blocked or binding blade, then try again. Depending on the age of the unit and frequency of use, the grinder motor may have failed and needs replacement.
Good luck.
Sep 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Hi, The ground coffee beans don't make it to the basket. How to fix this? Thank you,
First, you should call Cuisinart (800-726-0190) and see if your product is still under warranty. They may fix it for free. I was told that certain beans sometimes won't grind up fine enough to get through the screen in the grinder because of the oil in the bean. So first thing you can try is to freeze the beans and then try grinding them. If you have still have the problem, you either have an issue with your grinder or the grinder motor. You can buy a replacement grinder on Cuisinart's website for about $20. If its not the grinder, and its the motor the only thing you can do is find a spare motor online somewhere (impossible to find since they don't make spares for the motors; the only way to get one is from someone who has taken apart the same model for the parts). Hope this helps.
Dec 27, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Condensation- Cuisinart coffeemaker DGB-300
The condensation is normal, not just with this Cuisinart Grind n Brew, but with ALL Cuisinart Grind n Brews - because of this, you will really need to clean it after every use if you want the grinder portion to last long. As far as the bean amt - Cuisinart bases it's reccomendations on a smaller-than-normal coffee cup size of 5 ozs or so. Plus, the condensation, as you mentioned, will prevent a certain portion of the grinds from flowing to the brew/filter basket. Add more beans or less water to make a stronger cup.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 16, 2009 | Cuisinart DGB-300 Coffee Maker
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
103 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
