Question about Bissell 3040 Clean 'n Light H Vac Vacuum
Bissell model 3040 clean 'n light hand vac battery
How to replace battery
4 Suggested Answers
SOURCE: bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Posted on Mar 19, 2009
ukvacfan
  • 328 Answers
SOURCE: Bissell easy vac plus
Press the lock button down and forward (away from the
Canister Handle) while lifting the upper portion of the Dirt Cup
away from the Canister. The bottom box should then come out.
If you need a user manual for this model I have one and can send it to you if you email me.
Posted on Apr 02, 2009
SOURCE: Need replacement filter for Bissell Easy Vac Plus model 3102-0
I found a filter on GoVacuum.com It sells for 11.90 with free shipping.
Posted on Oct 12, 2009
Where find replacement battery for shark handheld vacuum
take the battery to a battery shop as most have records of batteries that are made
try the shop where you bought the unit as they may have replacement batteries in stock
May 23, 2015 | Shark Vacuums
Battery flashing
Normally a battery flashing is an indication that the battery either needs to be replaced or is low and needs to be recharged (if it's rechargeable)
Bear in mind that rechargeable batteries, such as those used in the robot-controlled vacuums do not have an infinite life. There will come a time when it will no longer take (or hold) a charge and have to be replaced. If this is your situation, take the vacuum (along with the charging station) over to a place called "BATTERIES PLUS BULBS" (there are stores all over the US) - these guys can very often rebuild the battery pack for less than half the cost of replacing it.
Good luck!!
Nov 01, 2014 | Vacuums
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Is it possible to replace the battery (loosing charge fast, weak power) for Electrolux stick vac EL 1000? Wher to buy the battery an dhow much cost? Thanks LJ
Jan 12, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Rechargable batteries need to be replaced
you may not need batteries just a new charging plug. if the batteries are damaged all you need to do is replace the handheld part of the pronto, this is where the batteries are located.
Jul 09, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
I need a new battery where can i get a low
The batteries inside the small hand held are NOT consumer replaceable. They are all soldered in place. If you are a handy with a soldering iron, you can replace the batteries yourself. I did and my Pronto 2-1 runs like new. I had it for about a year then it gradually lost its holding charge. I would only get about 2 minutes before it stopped.
Battery Replacement. First you will need new batteries. The batteries for the Pronto 2-1 are called NiMh 4/5 Sub C 2000mAh w/ TABS and can be purchased at Batteryjunction.com. You will need 8 of them. I paid a total of about $30 shipped. Next. Remove the 4 small screws holding the unit together. Once you have it apart you can get an idea of what is ahead. It took me about 45 minutes to cut out the old batteries and replace with new ones. Here are some helpful tricks. Use a knife to cut off the tab jacket about ¼ inch from the ends on all of the new batteries. Use a pair of needle nose pliers and tear off the battery tabs right off the OLD battery bodies. Replace the batteries ONE AT A TIME except for the group of 4 in the handle. The goal here is to solder the new battery tabs to the OLD battery tabs. This is much easier soldering tabs together than stripping and soldering the wires. REPLACE the batteries exactly how you see them. Add electrical tape where appropriate. Be careful when packaging the batteries back in place. I mentioned replace the batteries one at a time because this will allow you to verify your soldering. Press the on button and you should get the blower going. If not, you have a bad solder joint. Anyway, good luck. Jeff
Jul 20, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Replacement battery for a Shark rechargeable sweeper
Sure, take a look on amazon for replacement.. here: Finally charging for our multi device world. I hope this was helpful. Cheers
Feb 17, 2009 | Vacuums
Battery for electrolux pronto stick vac 2 in 1
This battery works perfect too (for your model), take a look on amazon: Amazon com tenergy 2 3a 1600mah nimh. Cheers
Dec 22, 2008 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Vacuums Logo
112 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
