Question about Bissell 3040 Clean 'n Light H Vac Vacuum
Bissell clean 'n light hand vac battery
How to replace the battery
2 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: Bissell easy vac plus
Press the lock button down and forward (away from the
Canister Handle) while lifting the upper portion of the Dirt Cup
away from the Canister. The bottom box should then come out.
If you need a user manual for this model I have one and can send it to you if you email me.
Posted on Apr 02, 2009
Does model, 3040 use batteries
It's a rechargable battery and they can wear out. Contact Bissell Consumer Care at 1-800-237-7691 for troubleshooting instructions or repair directions.
Jul 27, 2014 | Bissell 3040 Clean 'n Light H Vac Vacuum
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
My problem is that dust is shooting out of my powerforce bagless bissell. I pulled and detached the filters, hitting them againt my front steps which is cement, burshing my hand across the filter . Yes...
It could be a clog somewhere, a air leak somewhere and/or clogged filters. Cleaning filters does not necessarily mean they are not clogged. They should still be replaced quite frequently.
Sep 06, 2017 | Bissell 6594 PowerForce Bagless Upright...
While vaccuming it just stopped. Tried another outlet and checked power cord. Did find tube clogged with a dirt clog but no motor strain heard. Cleaned it out, Still not running
on the back of most vac's , u will find a red butten,use that to reset the vac. but even if that works u can avoid this usely buy ajusying the vac to a higher set . that helps reduse strian that the belt gets.
thanks
life's hand man
Mar 04, 2010 | Bissell 68001 Canister Vacuum
Need replacement filter for Bissell Easy Vac Plus model 3102-0
I found a filter on GoVacuum.com It sells for 11.90 with free shipping.
Aug 22, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
My bissell easy vac won't pick up after first use
Well after reading and re-reading my bissell easy vac manual (I had only used the vac twice), I went through all the troubleshooting recommendations. I cleaned out all filters and even though I had only used my hose attachment once, I was shocked that it was completely clogged! I took the whole thing apart and thoroughly cleaned it out according to the manufacturers instructions. It is working beautifully again now, I just take extra care to check it after every use...it can be a hassle, but I find that's what happens when you buy bargain items; you spend less but end up investing more time in upkeep. I hope this helps!! :)
Dec 20, 2008 | Bissell 3102-0 EasyVac Upright Vacuum
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Wanting to clean dog hair and dirt from my bissell proheat
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=608457
Generic problem for all Vacuums
Wanting to clean dog hair and dirt from my Bissell...
Posted by lil1939 on May 19, 2008
I would like to know where I can take my Bissell ProHeat to have it clean and gone over as it doesn't **** up the dirty water like it used to. I don't want to have to drive a 100 miles to have it fix, as I am elderly.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You may want to call Bissell to get a vac dealer in your area to service your Bissell and some of the vac dealers offer pickup and delivery @ a reasonable cost and they will do the service on your Bissell. Not knowing where you are writing from call the phone #’s listed below and they should be able to further assist you. Or you may have to ship your vacuum to the factory or a local vac dealer to service your unit. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 19, 2008 | Vacuums
I am wondering how I can clean the inside of my bissell spotlifter powerbrush hand held cleaner? I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49876&thid=506980
Posted by carriespets on Apr 12, 2008
I am wondering how I can clean the inside of my Bissell Spotlifter Powerbrush hand held cleaner. I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it comes apart or not so I can clean it. Can you help?
Normally on the Bissell Spotlifter Powerbrush the item will comes apart from the sides into 2 halves and then you can either clean out or blow out the inside of the
Bissell Spotlifter Powerbrush, also you can take a wire coat hanger and straighten it out and bend a hook @ the end of the wire hanger and you can use the hook to pull out the clog or whatever is blocking the opening and you can also use a blower or an old tooth brush to clean the motor or to brush it off.
Always, check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 12, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Vacuums Logo
27 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
