Question about HP LaserJet Office Equipment & Supplies
Hp laserjet p4015dn error message 49.4C02 What does it mean?
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 34 Answers
SOURCE: Troubleshooting error message 79 00FE on LaserJet 8000N
Yes...if you remove the jet direct card and your error goes away, be sure it is the jet direct card. If it says 600, or 610 on it, those cards had a lot of problems.
You can buy these rebuilt very resonably.
Posted on Mar 17, 2009
taran_2005
  • 10515 Answers
SOURCE: MY HP LASERJET 3005 DISPLAY ERROR 49.2F9D
Its already discussed in one of the forums for Hp.
check :-
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Posted on Jun 04, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
SOURCE: When sending document to my
When sending document to my HP LaserJet P1505, the engine scanner error message
Posted on Apr 25, 2011
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
I have a HP LaserJet 6040 with this error message 59.30
59.30 means that the fuser motor experienced a start up error.
If power cycling the printer won't clear the error you probably need a tech to troubleshoot and/or replace the motor.
Sep 16, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
When I switch on Hp laserjet P4015 it gives me initialising sound but without display please help? Samangwe
There is a firmware update for your printer. Click on the link below and download the firmware update and install. Turn off the printer and turn on after the update. Read the instructions to do the update on the web page.
Firmware Update
Regards,
Shawn
Feb 01, 2011 | HP LaserJet P4015dn CB526AABA Printer
Issues with HP Laserjet P3005n
That means that the output tray is filled to capacity, or one of the students broke the "bin full flag" at the top of the printer.
Feb 24, 2010 | HP Hewlett Packard LaserJet P3005n Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Jan 21, 2009 | HP LaserJet 4350 Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
102 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
