Question about Bosch Axxis WFL 2060 Front Load Washer
Washing machine replacement door seal
Have removed the outer wire which holds seal in place on a bosch washing machine but cann't see how you remove inner scred clip any answers?
  • Anonymous Jun 11, 2008
    I have a samsung wahing machine and can't figure out how to remove the old door seal to replace it.
  • Anonymous Mar 19, 2014
    Difficulty in removing the outer filter from my defy twinmaid washing machine
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this bosch Axxis WFL 2060
Posted on Jul 22, 2013
It is held on by a spring that stretches around the outside of the seal. The seal simply hooks on to a small lip so all you need to do is start in one spot and push it down and away. Then just work it around like removing a bike tire until it is fully removed. Be careful of the spring. It is hooked together so it may unhook once some of the tension is removed and snap around.
Posted on Nov 17, 2007
How to replace door seal on washing machine Bosch Advantixx ?
How to Replace the Door Seal on a Washing Machine - Bosch
One of the most common faults of a leaking washing machine is a faulty seal. Thankfully replacing such a component of your washing machine is not a difficult task.
In the above video, with the help of our experienced team, we explain how to replace the washing machine door seal, and below we've compiled a simple step-by-step guide which takes you through every point covered in our video.
Step 1: To remove the door seal on any make and model of washing machine, you'll need to remove the entire front panel, followed by the soap dispenser and fascia.
Removing the panel and fascia is easy to do, once you've undone the screws holding it in place, whilst the soap dispenser should just clip out of place.
Step 2: With these components removed, clip away the kick plate, put the drain hose to one side before removing the retaining clip which holds the door seal against the front of the machine. Once the clip has been removed just push the seal inside.
Step 3: Undo the four remaining screws holding the front of the machine on, before pulling the front of the machine and the door away from the machine.
Once the front of the machine is off, you should be able to see the spring retaining band going all the way around thedrum. This should be easy to pull off, enabling you to peal the whole old seal away; once you've removed the old seal this can be thrown away, although it is advisable to keep the retaining band, as this can be reused with the new seal.
Step 4: You'll now be ready to attach the new seal, when doing so make sure that the drain holes are positioned at six o'clock; once you've done this it is just a case of working the new seal onto the drum.
With the seal worked onto the drum, put the retaining spring into its little ridge, before giving the seal one final check.
Step 5: Reattach all the parts back to your washing machine, attaching the door seal to the front of the machine ensuring that it goes over the lip, before attaching the retaining band on the bottom and sides.
There you have it, a step-by-step guide to replacing the door seal on a washing machine, helping it to perform to its optimum level.
SAJID
How to Replace the Door Seal on Washing Machine Bosch
Feb 17, 2016 | Bosch Washing Machines
I have a new replacement seal for my Bosch Maxx 1000 front loading washing machine. How do I change it? There is a white ring holding the seal in place. How do I remove and replace that ring without...
The outer ring is remove quite easy / inner ring is secured by a screw , you need to loosen this to remove the seal....It is better to remove the front casing , make the job easy Two screws come off and it slides down to remove.........
Feb 14, 2011 | Bosch Washing Machines
Replacing door seal front loader bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
How do you remove front panel on a Bosch WFO285SGB
This video will show you how to replace the Bosch WFO285SGB washing machine door seal with step by step guide on the process
Aug 13, 2009 | Bosch Washing Machines
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Mar 09, 2008 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
287 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
