Question about Konica Minolta Magicolor 2590M F Multifunction Colour Printer Laser
Repeated paper jams - Konica Minolta Magicolor 2590M F Multifunction Colour Printer Laser
  • Konica Minolta Master
  • 6,161 Answers
Where is it jamming?????????????????
Posted on Jan 23, 2016
Repeated paper jam for Brother MFC-J475DW
The sensors that report paper jams often get little pieces of paper stuck inside tripping the sensor when jammed sheet gets pulled out. Powering off and restarting will not help this. You'll need to do a little bit of disassembly looking for loose bits of ripped paper. Maybe use canned compressed air to blow it out first.
Feb 07, 2015 | Brother MFC Office Equipment & Supplies
The copier experienced repeated paper jams
Pl. mention make/ model and where it jammed. if possible the photo of the jammed paper inside the machine. Also mention the total pages printed in A4 and A3 size.
Thanks.
Dec 13, 2014 | Office Equipment & Supplies
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
Repeated paper jam
Paper maybe stuck together by excess humidity or static before loading into tray try 'whirring' the paper set you are going to use.or warm the paper -light bulb will do
Sep 26, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Paper jammed under roller small piece of paper keep saying jam e3
Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
Procedure:
1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
2. press [maintenance] repeatedly until <b> appears.
3. press [black] or [color].
4. repeat steps 2 to 3 twice.
5. open the paper output tray.
6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
7. repeat steps 2 to 3 times.
the sheet paper is automatically fed in and then out of the machine.
have a nice day.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark x500n paper jam
Try cleaning the roller that picks up the paper. You can use a drop of alcohol to clean the roller.
Feb 07, 2010 | Lexmark X500n Color Laser All-in-One...
Paper Jam, when there isn't a paper jam!
just remove thr paper outer tray and see if there is any part of paper is there.
Sep 08, 2009 | HP Photosmart 3210 Printer
Menu says paper jam and there is no paper jam
Open every single cover on the printer and when you close the covers close them HARD. Don't break it tho :)
May 28, 2009 | HP LaserJet 2840 Printer
Paper jam message, but actually no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 25, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Konica Minolta Magicolor 2590M F Multifunction Colour Printer Laser Logo
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
