Question about Victorinox Aaa Led Aluminum Flashlight
Bulb replacement on a double Aa Victorinox flashlight?
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
How do you replace the LED bulb in a AA cell maglight flashlight
question is in TV section--answer would be contact Maglight to see if the part is even available and if not buy another flashlight.
May 04, 2012 | Televison & Video
Flashlight will not keep lighted, only flashes intermittently
i had one extend spring in cap slightly,also check diode is making solid contact with battery
Jan 08, 2011 | Victorinox AAA LED Rubber Grip Flashlight...
My Maglite torch that takes two AA batteries will not switch on. I think I require a replacement were the bulb fits into its connection.
The top just screws off and the bulb just pulls out....there should be a replacement bulb in the bottom cap under the spring inside that little plastic holder...just do not touch the bulb with you fingers when installing it. use a tissue paper to hold the bulb...
Line up the two little wires with the holes and gently press the new bulb in...
heatman101
Sep 21, 2010 | MagLite Mag-Lite& Flashlight
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
How do you change the bulb in a minimaglite
1. Unscrew the "bell" (top) of the flashlite. 2. Remove the bulb by pulling upward. 3. Replace with new bulb (be sure you have the correct bulb . . . it will have two small wires protruding from the bottom). 4. CAREFULLY insert new bulb through hole in the bottom of the reflector. 5. Screw the top of the flashlight back on.
Oct 22, 2008 | MagLite Camping, Backpacking & Hiking
Victorinox Aaa Led Aluminum Flashlight Logo
133 people viewed this question
Top Victorinox Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Victorinox Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
