Question about Apple iPod Audio Players & Recorders
Hold switch detect 1 - iPod Apple Audio Players & Recorders
I'm getting error code E000584-0001
E584
Main Cause The shutter open sensor (PI5) is faulty. The safety area detecting switch
(MS3) is faulty. The shutter closed detecting switch (MS4) is faulty. The
No. 2 feed motor (M8) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The shutter closed detecting switch does not turn on when the No.
2 feed motor has been rotated CCW for 1 sec or more.
0002 The shutter open sensor does not turn on when the No. 2 feed motor
has been rotated CCW for 1 sec.
0003 While the tray lift motor is in operation, the shutter closed detecting
switch is found to be off when the tray 1/2 is at OFF position
of the safety area detecting switch.
-David.
Nov 03, 2010 | Canon imageRUNNER 5000 Copier
I need to download music and there is no file for
Using XP, the player should be detected through the USB port of the computer as a removable disk [also called MSC device].
note:
Before disconnecting the player, always go through the icon "Safely remove hardware" in the right corner below of the computer screen, to keep the player free from data loss or data faillure.
First prepare the player before connection / check normal working of the player:
0. Player NOT connected to the computer
1. Switch the player ON using the >| button
2. Check the HOLD icon in the display: padlock should be OFF
3. When the padlock shows up, unlock the player: slide the HOLD switch to the left: padlock should not show in the display now.
4. Switch the player OFF, holding the >| for about 3 seconds.
When the player should not behave normal, perform a RESET.
0. Disconnect the player if connected to a computer.
1. Remove the battery from the player and leave it out for 10 seconds.
2. Replace the battery.
3. Power ON the player with the >| button and see if the player works normally.
4. Switch OFF the player, holding the >| button for 3 seconds.
How to check the detection of the MSC device on your computer:
0. Player Normal Functioning, NOT connected, NOT locked and switched OFF.
1. Explore 'My Computer': click start in the left corner below of the computer screen and select 'My Computer'.
2. Connect the MP300 to a USB port; detection may take some time.
3. Look on the computer screen if a new removable disk shows up in the explorer overview, coming up with a new drive letter.
4. Now you should be able to put music onto the player, showing up as a removable disk with the new drive letter: use 'copy and paste' or 'drag and drop' method for music transfers.
note:
When no new drive letter shows up, try another USB port.
Connect directly to the computer, not through a hub.
If you need more help, tell me at what point connecting or transferring fails in this thread.
There's also a software program called Coby Media Manager that can be used for detection or transfers. Coby Media Manager is based on MTP connection mode.
Need help for this ? Write your comment in this thread.
May 28, 2010 | Coby MP300 MP3 Player
Recently replaced the battery in my wife's 04 Solara. Now the sunroof will not work "automatically" like it did before. I now have to hold the button, when I only had to press and hold for a second before....
INITIALIZATION
1. INITIALIZATION OF SLIDING ROOF MOTOR
(a) The sliding roof AUTO operation and the jam protection function may not operate normally if the battery
is disconnected/reconnected, replaced or recharged. Initialize the sliding roof system using the method
below.
(1) Turn the ignition switch ON.
(2) Initialize the sliding roof by pressing and holding the TILT UP switch until the roof glass tilts upward
fully (the roof glass automatically tilts downward slightly after fully tilting upward).
(3) Release the switch.
HINT:
If the battery terminal is disconnected, the moon roof control ECU may not detect the position of the roof
glass. If the sliding roof AUTO operation is still disabled even after the sliding roof drive gear has been initialized,
the hall IC may be malfunctioning. The hall IC is built into the sliding roof drive gear and detects the
roof glass position.
If the result is not as specified, replace the drive gear assy (moon roof control ECU).
Apr 26, 2010 | 2004 Toyota Solara
What is E000584-0001
E584
Mode of
Detection
Mar 20, 2010 | Canon imageRUNNER 5000 Copier
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
It is fully charged and even when plugged into pc wont switch on?
try restoring it...here's how 1.flick the hold switch on and off a couple of times. 2.press and hold menu and center buttons together until an apple logo appears on screen. 3.Once the apple logo appears and it goes  to disk mode,connect to system. 4.itunes should detect it in recovery mode.Use the restore option to restore your player.
Sep 25, 2009 | Apple iPod nano
Sansa view is no longer recognized when plugged into USB port
A Soft Reset
3. Restart
B. Hard Reset
2. Restart
C. Recovery Mode
9. Restart device
8. Restart device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Ipod is not switching on
1.download the appropriate firmware from here 2.press and hold reset button for 2 seconds 3.run the firmware updater 4.press and hold "play" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware.
Sep 02, 2009 | Transcend T.sonic 610 MP3 Player
I connected my i pod 2 the computer and it showed me a messagae saying error in usb device.and after that it got stuck i cant it switch it off and its not even getting detected by my laptop,the light keeps...
Try reseting the iPod.
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
-Logan
Dec 12, 2008 | Apple iPod nano
Sony NWd-B103 BLK 1 GB
Hey, guys. I just fixed this problem. My mp3 cant be detected at first too. You have to hold the play button when you connected the computer. Then the computer will detected. After it be detected, update the firmware. It 100% works. and fu*k sony.
Mar 21, 2008 | Sony NWZ-B103FBLK MP3 Player
18 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
