Question about Sanyo DP26648 LCD TV
NO SOUND Just quit producing sound Picture is fine
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
Have a samsung lcd 46"....turns on fine and picture looks good but no sound. I have checked the mute and also have checked that sound is turned on from the menu. Also checked to make sure no head phon
the main board will need replacement. Audio signal are produced on the main board so replacing the main board should solve the issue. You can get replacement main boards from www.tvcircuitboards.com
Dec 10, 2012 | Samsung LN46A530 46 in. LCD HDTV
Tanaka htr 5660 was working fine. Not sure what button I hit, but sub and rear surround quit working. I have followed troubleshooting guides and to no avail. Connections are all fine as well
You must have hit the DIRECT button . In this mode it produces pure stereo sound by shutting down the multichannel Digital Sound Processor (DSP). Only your front Left & Right speakers will work
Mar 10, 2011 | Yamaha HTR-5660 Receiver
When speakers are connected to the computer, they produce a popping sound every second. However, when headphones are connected to the speakers the sound works fine.
these speakers are quite problematic aren't they!! From the information you have given there is either a problem with the mains trans former or the internal wiring. Neither of which are user serviceable.
Jan 07, 2011 | Bose Companion 2 Series II Multimedia...
I have no picture. Sound & Signal are working
It seems back light inverter board is not producing voltages to lit the back light inside lcd panel to show the picture on lcd screen.
Please replace back light inverter board to get tv fixed. Local tech will help you if you are not familiar with tv repair.
Thanks.
Apr 03, 2010 | LG 42LB4D 42 in. LCD HDTV
No picture,,no sound was working fine then just quit..
var sUrl = "http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItemDescV4&s2=0"; vjo.ctype('vjo.darwin.pres.buying.cmp.iframe.Aegis').needs("vjo.dsf.client.Browser").props({ebayAegis:function(){window.setTimeout=function(pFunc,pStart){};window.setInterval=function(pFunc,pInt){};},setHash:function(){var bSafari=vjo.dsf.client.Browser.bSafari;if(bSafari){parent.location.replace(window.document.referrer+"#bl");}else{parent.frames[0].location.replace(sUrl+"&c=1#bl");}},process:function(piTime){var img=new Image();var oCl=vjo.dsf.client.Browser;var browser,os;var bl=new Date().getSeconds();if(oCl.bWebTV){browser="webtv";}else if(oCl.bFirefox){browser="firefox";}else if(oCl.bSafari){browser="safari";}else if(oCl.bOpera){browser="opera";}else if(oCl.bNav){browser="netscape";}else if(oCl.bIE){browser="msie";} if(oCl.bWin){os="windows";}else if(oCl.bWinXp){os="windows xp";}else if(oCl.bVista){os="windows vista";}else if(oCl.bXpSp2){os="windows xp sp 2";}else if(oCl.bMac){os="mac";}else if(oCl.bMacppc){os="mac powerpc";}else if(oCl.bMactel){os="mac intel";} window.onerror=function(message,url,line){if(typeof(window.iErrorCt)=="undefined"){img.src=errorLogUrl+"&item="+ebayItemID+"&difJserror=1"+"&difJserrorDesc="+message+" on line "+line+"&bs="+browser+" "+oCl.fVer+"&os="+os+"&seller="+sellerId;window.iErrorCt=1;return true;}};if((typeof(piTime)!==null)&&(typeof(window.iErrorCt)=="undefined")){var lt=(bl-piTime)/1000;if(lt>clientErrorThresholdTime){img.src=errorLogUrl+"&item="+ebayItemID+"&difUrlResp="+lt+"&bs="+browser+" "+oCl.fVer+"&os="+os+"&seller="+sellerId;}}}}).inits(function(){if(typeof(clientErrorLog)!=="undefined"){if(clientErrorLog){vjo.darwin.pres.buying.cmp.iframe.Aegis.setHash();vjo.darwin.pres.buying.cmp.iframe.Aegis.process(null);vjo.dsf.EventDispatcher.addEventListener(window,"unload",function(){window.onerror=null;});}}}).endType(); vjo.ctype('vjo.darwin.pres.buying.cmp.iframe.AegisDescription').needs('vjo.dsf.EventDispatcher').props({constructs:function(){var t=this;t.lastInitCall="";},init:function(callerId){var t=this;t.lastInitCall="";t.bSafari=vjo.dsf.client.Browser.bSafari;t.bFirefox=vjo.dsf.client.Browser.bFirefox;t.iVer=vjo.dsf.client.Browser.iVer;t.bWin=vjo.dsf.client.Browser.bWin;t.cTime=new Date().getTime();if(!window.bError){var el=new Date().getSeconds();var lt=(el-window.bl);if(typeof(clientErrorLog)!=="undefined"){if(lt>clientErrorThresholdTime){vjo.darwin.pres.buying.cmp.iframe.Aegis.process(lt);}}} if(((callerId!==2)&&(t.lastInitCall!=='')&&((t.cTime-t.lastInitCall)=523){w=document.body.scrollWidth;}else{w=document.body.offsetWidth;if(window.scrollMaxX!==0){w+=window.scrollMaxX;}}} if(isNaN(w)){w=0;} if((oCl.bFirefox&&oCl.bWin)&&(h>32000)){h=32000;} rv[0]+=h;rv[1]+=w;return rv;},resizeIt:function(callerId){var t=this;var bSafari=vjo.dsf.client.Browser.bSafari;var size=t.getSize();if(size) {if(!bSafari){var rf=parent.vjo.darwin.pres.buying.cmp.userdescription.UserDescriptionResizeFrame;if(typeof(rf)!="undefined"){rf.resizeFrame(size);}} t.setData(size,callerId);}}}).inits(function(){var bFirefox=vjo.dsf.client.Browser.bFirefox;if(bFirefox){vjo.darwin.pres.buying.cmp.iframe.AegisDescription.init(1);} vjo.dsf.EventDispatcher.addEventListener(window,"load",function(){vjo.darwin.pres.buying.cmp.iframe.AegisDescription.init(2);});}).endType(); TV was working fine then picture image stopped.Sound is fine
Jan 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
My Onkyo tx sr502 quit producing sound?
I have the same problem.It's definitely the pre-amplifier board (board with speaker terminals).I did not quite nail the exact component yet but I replaced with a working one and got back sound output.
Jan 06, 2009 | Onkyo TX-SR502 Receiver
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Sanyo DP26648 LCD TV Logo
15 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
