Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
I am getting a F-35-6 error on a Konica Minolta 7022
I think it is a thermistors -needs cleaned and then reset ???
I need pictures/instructions on how to find, take out, clean and reset.
Thank you!
Cindy Randolph
RR 3 Box 7833
Doniphan, MO 63935
573-996-3600
cindymeds@gmail.com
    Sergeant:
  • 210 Answers
I assumed that you know how to take it out the fuser / fixing unit from the copier. There are two way to access the thermister. One if just want to clean the surface of the thermister is by removing the upper claws holder bracket, upper web black cover with 2 upper shoulder screws four screws from the rear and front on the left side of the fixing unit and one screw in the button center. remove the web assembly, Remove the heat lamp, and remember which is the rear and front of the lamp which one is upper and lower on one end of the lamp is on the rear is black, Remove fixing roller which you need the spreader toots to remove the C clips at the front and rear of the fixing unit. now you have the access to clean the thermister. clean it with alcohol and use any sharp object to scrape the toner. you can easily damage the thermister. To put it back together you have to do it in reverse of disassemble. to reset the code press P on the key board enter 9272 choose the 25 mode and may see on the menu to reset the fixing code. I hope that this will help you. Get back to us if you run in to a problem and a question.
HH
Posted on Aug 12, 2009
    Problem Solver:
  • 17 Answers
Can u tell me model of machine?
Posted on Jul 07, 2009
  • syed naeem Jul 07, 2009
    can u tell me model of machine?
2 Suggested Answers
Nitrotrike
  • 589 Answers
SOURCE: Konica Minolta 7022- How to clean- Getting Dark Lines on Copies
Beings as it is close to 100k, it is due for a PM (preventative maintenance) kit to be installed (this model has a 100k PM cycle), and also a web, corona wires, charge grid, and feed rollers (if worn) should be replaced at this point, and of course cleaned.
The drum and developer "should" last 200k (this can vary greatly).
$200 for a general cleaning on that series machine... that's entirely too much, and he will most likely tell you it's due for a PM. A competent technician would be able to install the kit, replace the above parts in under 2 hours easily.
I wish I could be of more help, but given that is almost at the end of its PM cycle, it could be anything.
Posted on Feb 12, 2008
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
Hi, I have a Konica 7022 and it comes up with the error code PLEASE CALL SERVICE F-35-1 . Can anyone please advise a fix to this problem. Jack
I would call for service. Below is the official repair method. Sounds like a fuser has failed or at least the thermistor on the fuser. This ensures there is enough heat in the device to properly transfer the image to the page.
F35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Mar 01, 2011 | Office Equipment & Supplies
Konica 7022 copier at start up says call service and shows F-35-3
The thermistor TH1 on the fuser unit is coming up as faulty this will cause your f-35-3 error you can reset it in service mode 25 dip sw3 0 to 1 however i do not do this as there is an issue i would replace both thermistors and look at the fuser unit for wear if in bad shape replace the fuser unit assembly
Jan 22, 2011 | Konica Minolta Office Equipment & Supplies
I have a konica 7022, it says call for service code F-35-3. what's wrong with it. please help me.
Fixing upper roller low temperature error.Verify the continuity the heater lamps and remove and clean the thermofuse.If the thermofuse not working change it.
Sep 25, 2009 | Konica Minolta Office Equipment & Supplies
F-35-4 this is over problem
Fuser error: lamp, thermistor, fuse problem, etc. Part needs to be replaced and code reset in service mode only. Call a tech
Jun 20, 2009 | Konica Minolta DiALTA Di200 Copier
Error code F-35-6 on my konica 7022 copier
You could try to reset the code. F35-6 is a fuser code, either you have a power surge later or bad thermistor in the fuser unit. Power off your machine, while hold down 2 and 5 button power the machine, this should take you to the 25service mode. in the softswitch mode go to switch #3 turn bit 1,2 and 3 to 0. than power off and on your machine. if this doesn't work you need to replace your thermister and possibly the thermostat.
Sep 17, 2008 | Konica Minolta Minolta DI1610FP...
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
348 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
