Question about Zanussi Washing Machines
Clothes still wet, after an extra spin and drain. Have take filter out and now blockage. Machine just under a year old
COXY
  • 76 Answers
SOURCE: Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Posted on Nov 30, 2007
vest6
  • 196 Answers
SOURCE: broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Posted on Jan 08, 2008
  • 958 Answers
SOURCE: whirlpool spin problems
i'll try that link tech 17... tnx...
Posted on Feb 12, 2008
  • 96 Answers
SOURCE: series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Posted on Mar 20, 2008
SOURCE: Roper washer leaves clothes wet after spin cycle.
Thanks, Master Tech; I was having the same problem as Jason. When I put the pen in place, I realized that the motor was running, but the tub wasn't spinning (which I thought it was because of the sound of the motor). So, I put my hand in and gave it a push/spin and it started turning on its own after I did that.. So, I'm going to let it run and see what happens when the cycle is done. At least its a start in the right direction!
Posted on Aug 04, 2008
Clothes still wet after cycle
you need to check
1 pump for things that should not be there
2 both hoses to the pump are not blocked
3 worst case change the pump it may be worn
Feb 07, 2014 | Zanussi Washing Machines
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
My washing machine use to wash our clothes so well that they would come out of the washing machine practically dry... now i have to run extra spin cycles just to get some of the water out. My display often...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
After washing clothes are still coming out wet
If its a washing machine there going to be wet arent they lol.
right if you mean that they are soaking wet after spinning it could be that the water is not draining away fully, have you checked the filter and cleaned that out, usually at the front of the machine on the bottom right. try draining that, or there could be a blockage in the waste pipe,
hope that this helps
Feb 28, 2009 | Hotpoint WMA30 Front Load Washer
Clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Dec 17, 2008 | Maytag Washing Machines
I have a WF220, 1200 spin washing machine (3.5 years old and very little use) which does not complete the washing cycle. Each light comes on as the programme progresses until all the lights are lit...
You may find that the internal filter is blocked & that by stopping and starting the machine you are giving it extra time to complete the drain cycle. The filter is located at the bottom rear of the machine & is secured by a large hose clip to the bottom of the drum. Try filling the washer with no clothes in & then switching to the drain programme to see if the water drains properly
Nov 03, 2008 | Washing Machines
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
