Question about Swiss Burett Neo Abyss Chronograph Stainless Steel , # B4602ND Watch for Men
Burett neo abyss chronograph B4202NB manual
Reset chronograph after replacing battery
How do I reset emporio armani ar5950 chronograph to zero after replacing the battery.?
pull crown out to second position ,then press bottom button till it goes to zero then push crown back in job done,,if you want to do both dials press and hold bottom button so they rotate faster to zero then press one press at a time...
Nov 21, 2014 | Emporio Armani Mens AR5950 Brown...
How do I set the chronograph on my manual Omega 1964 Seamaster wristwatch?
The chronograph resets at 0 on the recorder hands and the crono hand resets at 12:00
hope this helps.gabe
Oct 20, 2014 | Omega SeaMaster Watches
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
Just bought the watch, I set the time but the clock is not running. does it come with a battery? should I return it?
kindly check the lower sub dial if it is working. if yes, you don't have to worry because it is a chronograph. if not, check the crown if it is pushed down, if not, you got to push it, and if nothing happens you have to bring it back from the seller probably the problem is the battery. I hope i had been helped you.
Jul 27, 2011 | TechnoMarine NEO CLASSIC LADIES WATCH...
I have a Technomarine abyss, bought as used and don't know if working. Once open to change battery I found that there's oil also in the bak where is tored battery. Is it normal or the watch is...
Hi. It has silicone oil in it. To tolerate diving to that depth the watch is capable. It is normal, but if the silicone has to be completed if some leaked. Take it to the repair service. Best regards!!!!!!
May 13, 2011 | TechnoMarine Abyss ABS01 Watch
Reset chronograph
Hi, I had the same problem and was able to fix it by reading the manual:
Basic Settings for the chronograph hand -
After changing the battery, or in exceptional circumstances, following incorrect operation, it is necessary to reset the Chrono indicator to zero (starting time).
- Leave the winder in Position 1 (pushed all the way in)
- Press button H (top) and button I (bottom) at the same time
- Now set the 30 minute (small hand) counter to zero by pressing/holding button I (bottom button)
- You can now set the 60 second counter to zero by pressing/holding button H (top button).
This worked for me... it took me a while to figure it out, but that
Jun 04, 2010 | Maurice Lacroix Masterpiece Flyback...
Stopping after 12 or 24 hours
Read your manual carefully and you will notice that the big, tall seconds hand is part of chronograph function. So, by pushing upper button you are actually engaging chronograph. This puts more strain on movement gears and consumes more battery power. When your watch is in normal timekeeping mode, the small seconds hand is counting seconds, not the big one which should be steady pointed at 12. I would recommend to put a new battery in your watch, reset it and start using it as described in users manual. You can download users manual here: http://www.oakley.com/customer-care/support/watches
Rate me, plz.
Jan 10, 2010 | Oakley Detonator OAK0530 Wrist Watch
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Reset tank franchase cartier
Not completely sure what is being asked.
If what is being asked is how to reset chronograph hands to their zero point on a quartz watch then do the following:
1) Pull the crown out to the setting position.
2) press the chronograph buttons. Each one will move a different hand.
3) Once the hands are set push the crown back in.
Normally the zero point needs to be reset after a battery change or if the battery in the watch is getting weak.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Cartier Tank Francaise W50005R2 Watch for...
Swiss Burett Neo Abyss Chronograph Stainless Steel , # B4602ND Watch for Men Logo
Top Swiss Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Swiss Watch Expert? Answer questions, earn points and help others
