Hi I have hotpoint hvf344 wont finish its cycle making a buzzing noise the drum is full of water red key is showing and is also trying to trip my electricity owt could you help me please
2 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: Hotpoint Aquarius 1000 WM62, fills then trips the house electrics
This sounds very like you've got an insulation breakdown in the heating element, or in the wiring that leads to it. When the water level gets high enough, the machine switches the heater on to start warming things up - at which point the fault gets taken into circuit and blows everything. You already know all the stuff about switching off and unplugging before you start. If you hadn't just been working on the machine, I'd have said just to lash out £23 on spec. and fit a new element. Under the circumstances, it might be worth doing a few checks first: 1. Although you're sure you've replaced all the wires correctly, just triple-check you haven't swapped live and earth at the element. 2. Inspect the wires that run to the element to make sure none of them are chafed or trapped, and that none of the connectors are fouling anything they shouldn't be. 3a. If you can get hold of an insulation tester, use it to check the element earth-live resistance (with all wires disconnected). This should be of the order of a Megohm or more - but will be much less if the element casing has leaked. 3b. On the assumption you haven't got an insulation tester in your back pocket, try this instead: Carefully disconnect the live wire from the element, make it safe with tape if you need to, then try to run the machine. If the machine now fills properly without taking the trip out, then this is a pretty good pointer towards needing a new element. A.
Posted on Feb 18, 2007
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
How do i fix my washing machine interlock hotpoint hvf 344
The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
Jun 29, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Door stuck
try unplugging and plug back in to reset
Nov 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wm53 unknown problem
Hi.
Unplug the motor and try it again, if it does not trip, then the prob is the motor, could be worn carbons.
Re the noise, remove belt, and spin drum round by hand, if it is noisy and rumbling, then main bearings have failed, quite a big job to put right.
Please rate my comments.
Thanks.
Jun 17, 2009 | Hotpoint Washing Machines
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint WD72 - Plug Fuse Blows on Final Spin/Rinse
Hello thesquiffys
Welcome,
You said,
During final spin/rinse a vibrating/buzzing noise begins behind the from panel and which appears to be coming from just to the right of the soap drawer. After a few seconds, either the trip throws on the household consumer unit, or on one occasion, the fuse in the mains plug blew as well. Have noticed (don't know if connected) that soap drawer is often found containing water after machine is finished.
1.The soap dish needs to be cleaned out, holes clogged. The instructions for this
process is in the user guide and I'll paste the site below for you in case you do not have it available to you.
2.The noise sounds like a short or electrical problem starting.
For this you will need a hands on diagnoses.
TRY doing the soap drawer first to be sure that it is not the culprit!
The book can be found here and the drawer info on page 12:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HBWD72.pdf
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank You
Sep 28, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
