Question about Automate AM6.2
Cannot locate the valet button
The installer may not have installed the valet button, how do I bypass or override it?
Where is the valet button override button in 2004 dodge durango
the
valet/overide button, found under the
dash area
Mar 25, 2014 | 2004 Dodge Durango
Car starter in valet mode
  1. 1 Insert the key into the ignition.
  2. 2 Turn the ignition switch to "ON." Do not start the engine.
  3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
  4. 4 Release the valet/override button after the security indicator light turns off.
  5. 5 Turn the ignition switch off.
Dec 07, 2013 | Dodge Cars & Trucks
Valet/Bypass Switch Location 1995 Honda Accord
Wow no idea at all ,is this the original factory alarm or a add on one
Jul 17, 2013 | Prestige Aps95bt2 Elvat5c Replacement...
Valet switch location
The valet switch is usually located around the drivers side. Each installation is different, as are most alarms. The valet switch could be part of the flashing LED or, it could be incorporated into the on glass antenna. If not, it should be located below the driver side dash. If you can see the alarm, locate the blue two pin plug and trace the wire to the push button valet. If the unit is manufactured by Directed (Viper, Python, Avital, Clifford, Valet, Automate, Hornet, etc.) turn ignition on then off, press and release valet within 10 seconds, LED will illuminate solid to show system is in valet. If the unit is manufactured by Audiovox (Prestige, Pursuit, Code (new)) turn ignition on, press and hold valet switch for approx. five seconds, release, LED will illuminated solid to show system is in valet.
If you are attemting to manually override the system, turn ignition on, press and release valet switch to disarm.
Aug 21, 2012 | 1995-1997 Chevy Tahoe Ignition Starter...
I lost remotes,how do i bypass alarm?
Locate the valet/override switch. You may have a push button LED or, it may be located under the drivers side of dash. Turn igniton on press and release push to manually override alarm. Turn ignition off then, back on. Press and hold push button for approximately 5 seconds to put alarm in valet.
Jul 18, 2012 | Car APS25CH Prestige 2 Button Remote...
I have a 2000 dodge intrepid. The alarm never worked on it. We bought it used and all of a sudden when we go to unlock the door it turns on. Now the car won't start. I've looked online for answers and...
The 2000 Dodge Intrepid is equipped with an alarm system that is triggered when unauthorized entry is attempted. In some situations, such as having the Intrepid valet parked or when it is being serviced by a mechanic, the alarm system needs to be disarmed so it doesn't go off. Disarming the alarm will prevent it from being activated until it is armed again.
Difficulty: Moderate Instructions
have to do it in this order
Dec 10, 2010 | 2000 Dodge Intrepid
Have a code alarm for car remote dont work and cant disable it. wont start how do i disconect alarm so car will start
Provided that your system is not programmed for coded override, the standard emergency override is as follows:
1. Enter the vehicle (the security system will trigger.)
2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver)
3. Turn the ignition key to the ON position.
4. Press and release the emergency override button (The security system will turn off).
Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
1. Enter the vehicle (the security system will trigger).
3. Turn the ignition switch to the ON position.
4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1).
5. Within 5 seconds turn the ignition key OFF, then ON.
6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1).
7. Within 5 seconds turn the ignition key OFF, then ON.
8. If entered correctly the security system will turn off.
9. Turn the ignition key to the OFF position.
If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
Aug 03, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
My glove box valet lock is on, how do I override
Your black ended driver key should open the glove box. The valet key is not made to open it, thats the safty feature in it. There is no overide for the Valet settings, you have to unlock the glove box with Driver (master or black) key and turn the Valet switch off. Also the Valet switch does not engage the glove box lock so over riding the Valet security wouldnt open it even if you could over ride. If the Valet key would unlock it or was easy to overide then it wouldnt be a very good safety feature. Best of luck, hope you can get it opened.
Jul 28, 2010 | 2001 Oldsmobile Aurora
Car starts then runs for about 4 seconds and shuts off right away. it will stay running if i use the command start info; 2001 grand prix. aftermarket astro commandstart lost the starter and need to get it...
There is usually a over ride switch "valet" switch that should have been installed with your aftermarket starter. Your going to have to locate it and turn the valet switch on for you to get the car started with your keys. Call the installer and they should be able to tell you where it is or as mentioned, look for the switch. It's going to be under the dash somewhere around the drivers area and will not look like a factory switch built for the car. Good luck and keep me posted.
Jan 13, 2010 | 2001 Pontiac Grand Prix
I want to turn off factory installed alarm in 1999 Ford Taurus SHO but where is the switch located?
Hi there. As far as the valet/overide button, it's a hidden
device-switch, a little spring loaded micro button,
red or black possibly and is probably down under
the dash area, near your knee/leg. In some
remote start/alarm combos, the antenna on the window
glass will also have an override/valet button.
Older sytems will have a flip type toggle switch.
When you locate the button or switch,
turn on the ignition key, press and hold
in the button until the alarm chirps 1 time
(for toggle types, key on, flip switch in the
opposite direction, then key off). This should over ride the system. You would get a single chirp to confirm from the siren.
The LED (light emiting diode) light in the dash
should also go on solid. This is valet/overide/reset.
This should correct any issues like starter disable,
or anti-hijack. Your keyless entry, if installed,
will still be operable. The have it inspected for the
falsing issues you are experience at a local shop.
You would repeat the same steps to toggle back into user mode.
Sep 01, 2008 | Ford Taurus Cars & Trucks
Automate AM6.2 Logo
96 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
