Question about Dell Precision M6300 Notebook
Dell Precision M6300 lights blinking
It won't boot up. It starts to boot, beeps once and the three lights above the keypad, the one on the left solid color, middle one blinks and the one on the right solid color. Then it turns off, what is wrong?
MysteryFCM
  • 187 Answers
SOURCE: Blinking Lights, Computer Wont Boot
If it's blinking 9 times then it's likely telling you one or more of the RAM sticks are in need of replacement. To check these, remove the laptops power cord and battery, then locate and remove, the cover for the RAM. Remove one chip at a time and try booting the laptop.
Posted on May 25, 2008
  • 998 Answers
SOURCE: Dell Precision M70 PC booting problem
There’s probably an issue with your boot-up files or the hard drive. Suggest you start backing up all your documents, pictures and anything else that you don’t want to lose. Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. If no errors are detected, your software has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 26, 2008
RSBennett
  • 54 Answers
SOURCE: Dell M70 laptop won't boot up
If you have a Windows installation CD, you can use the Recovery mode to attempt to fix the problem.
Turn on computer, insert CD into drive.
Press any key to boot from CD
Windows installation process will start
After a few minutes, a screen will come up telling you to hit ENTER to install Windows, or to press R to enter the Recovery Console
Press "R"
You will be asked which operating system
Most times there is only one option, select 1
At command prompt, type "fixboot" and press ENTER, if it asks if you're sure, type "Y" press ENTER again
Then, at command prompt, type "fixmbr" and press ENTER, again, type "Y" and press ENTER if it asks.
Type "exit" and press ENTER to exit recovery console and reboot.
Give that a try and see if it will boot for you.
Posted on Mar 08, 2009
El Geek
  • 149 Answers
SOURCE: Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Posted on Jun 03, 2009
  • 97 Answers
SOURCE: dell precision m60 press the power button the
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil pmgibs1@verizon.net
Posted on Feb 23, 2010
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Black screen only comes up when the start button is pushed
Please tell us where it stops. Can you enter bios or are there any beeps or any lights on? Any further info might help!
Mar 29, 2014 | Dell Precision M6300 Notebook
Reset bios password
Each Dell has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Supporticon1.png at (800) 624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Precision.
Jan 22, 2014 | Dell Precision M6300 Mobile Notebook
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Dell precision m6300 battery won't charge.
You say it's a new battery. Is the battery the same EXACT spec? Some aftermarket batteries don't work well with your laptop. The pin-out/connections may be incompatible. That said, in your BIOS is there a "Battery Learning" section.
Jan 04, 2013 | Dell Precision M6300 Mobile Notebook
Dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Dec 07, 2011 | Dell Precision T7500 Computer Workstation ...
M6300, When I push the power botton, the green power light lights up, and for a second the next light lights up ( i think the hard drive light) then goes out to stay out. screen stays black no boot up...
Try taking the battery out of the machine and leave it hooked to the AC power and try it again. It may be that your battery is bad and that is stopping it from booting up.
Apr 21, 2011 | Dell Precision M6300 Mobile Notebook
My m6300 power light blinks 4 orange then 1 green, very quickly. it also hangs on boot.
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 22, 2010 | Dell Precision M6300 Mobile Notebook
Why is my m6300 not booting up? I installed a new cover and HDD and the screen is blank when I power up. There is a beep and nothing. I removed the BIOS battery and placed it in the new cover before...
Screw you laptop check the RAM remove it and clean with a eraser use another slot of the RAM. Put back the RAM. If the same things happen and no beep.
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
Mar 26, 2010 | Dell Precision M6300 Mobile Notebook
Dell precision m6300 tunup
Click on this link and select your operating system to to get all of the DELL Precision updates from the DELL website. You can also shop there store to upgrade your RAM (memory stick)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PREC_M6300&os=WW1&osl=en&catid=&impid=
Oct 27, 2009 | Dell Precision M6300 Mobile Notebook
Dell Precision M6300 Notebook Logo
69 people viewed this question
Alun Cox
